04 CTS-V sunroof doesn't work
Results 1 to 6 of 6
2004-2007 Cadillac CTS-V General Discussion Discussion, 04 CTS-V sunroof doesn't work in Cadillac CTS-V Series Forum - 2004 - 2007; I have a 2004 CTS-V with a nonfunctional sunroof. It doesn't do anything. I tried doing the reset procedure but ...
    ruskiyab is offline Cadillac Owners Member
    May 2013
    6
    I have a 2004 CTS-V with a nonfunctional sunroof. It doesn't do anything. I tried doing the reset procedure but that didn't make it it work. When I turn the dial to different positions I hear a faint click that sounds like a mechanical relay. Is my motor toast or is there something else I can check?
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,162
    Re: 04 CTS-V sunroof doesn't work
    See attached.
  3. #3
    May 2013
    6
    Quote Originally Posted by darkman View Post
    See attached.
    Thanks, that doesn't really help though without pinouts and part locations. Does a relay normally operate if the switch is bad? I'd imagine it wouldn't.
  4. #4
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,162
    Quote Originally Posted by ruskiyab View Post
    There is a fuse/relay in the right rear fuse block. There is also a switch and a module. See attached. (I do not have a sunroof, so I have no direct experience on this.)
  5. #5
    May 2013
    6
    Fuse is good, when I removed it, the relay wasn't clicking with the switch. Must be something else. Guess I'll be taking down the headliner.
    You wouldn't happen to have the procedure to lower the headliner would you?
  6. #6
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,162
    See attached.
  7. Remove Advertisements
