05 V Sunroof issue
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, 05 V Sunroof issue in Cadillac CTS-V Series Forum - 2004 - 2007; Noticed yesterday when I shut Driver door, the front of the sunroof lift up abt. an inch or 2. It ...
    gregj1006 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Aug 2009
    45
    406
    05 V Sunroof issue
    Noticed yesterday when I shut Driver door, the front of the sunroof lift up abt. an inch or 2. It opens and closes fine. is this normal?
    Appreciate any/all replies
  2. #2
    tophat is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Aug 2012
    minneapolis mn
    39
    120
    Re: 05 V Sunroof issue
    Mine does that also, doesnt seem like it moves that much tho. I dont have any leaks or anything so I assume alittle movement is normal as the air pressure changes by closing the door. Id say if it doesnt leak then its probably normal.
  3. #3
    Wingsfan4life's Avatar
    Wingsfan4life is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V Black Raven
    Aug 2011
    Brooklyn Center, Mn
    46
    232
    Same on my 05...it doesn't leak water, but you can hear wind..I'm assuming its the switch..I think there's a TSB on it as well..
  4. #4
    Aug 2009
    45
    406
    Ok thanks. Will keep eye on it
  5. #5
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    See attached.
  6. Remove Advertisements
