Code PO449 Evap Purge Valve
Results 1 to 9 of 9
2004-2007 Cadillac CTS-V General Discussion Discussion, Code PO449 Evap Purge Valve in Cadillac CTS-V Series Forum - 2004 - 2007; Alright guys and girls, Car threw a check engine light code PO449. I have looked on here an talked to ...
    2005_CTS-V's Avatar
    2005_CTS-V is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Dec 2012
    Lafayette, IN
    98
    Car threw a check engine light code PO449. I have looked on here an talked to the dealership and know it requires me to drop the rear cradle. My question to you all is, what all should I replace while the rear cradle is down, bushings etc.? Thanks for the help!
    -Josh
  2. #2
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    Are you positive it is the vent valve that is bad?
    I dropped the cradle and replaced the vent and still had the code, came to find out it was a corroded plug causing my problems.
    I'd do cradle bushings, diff bushing, and stainless braided brake lines while the cradle is out. (You have to undo some brake lines to drop the cradle, might as well upgrade when you have them half way out. )
  3. #3
    2005_CTS-V's Avatar
    Dec 2012
    Lafayette, IN
    98
    Guess I will check the plug first when I drop it. Already upgraded to stainless lines when I painted calipers.
    Any recommendations on what bushing kit to go with? And does the front carrier upgraded brace over factory help?
    Thanks for the good info!
  4. #4
    Nov 2009
    Wisconsin
    33
    785
    I had plug repaired at the dealer, I believe they were able to rewire it with the cradle in the car.
    People say the 95A (red) RevShift cradle bushings and diff bushings are good. I haven't gotten them yet.
    I don't thing the diff pinion brace is really needed.
    You should read up on the cradle bushings, getting the old ones out is not easy.
  5. #5
    PJGross is offline Cadillac Owners Fanatic
    Apr 2008
    168
    Re: Code PO449 Evap Purge Valve
    Have the dealer properly troubleshoot the code! I had the code for the EVAP system for 8 months. I didn't want to just throw parts at it, but my EVAP can didn't have a visible crack like others. I finally took my car to the local GMC dealer where our Traverse is serviced at since I didn't have a way to pressurize the system with smoke to check for leaks, etc.
    Anyway, mine ended up being a bad purge solenoid. The solenoid is NOT under the car, its up in the engine compartment. The total was $200 or so which included the part, changing it out, and troubleshooting. WAY less than doing anything with the cradle.
    If it was the EVAP can itself, I planned on just paying for the troubleshooting and doing the whole cradle update myself. I've been code free for 3 months or so now. The troubleshooting sheet from GM and diagram have been posted several times here if you search for it.
    Good luck and hopefully it is just the solenoid! (or not if you want to do cradle bushings.
    -PJ
    I agree with the above, don't assume anything. The EVAP code can be for several things, so
  6. #6
    2005_CTS-V's Avatar
    Dec 2012
    Lafayette, IN
    98
    Great advice guys!!! I am heading to the dealership today to see what parts for both of the areas that you've talked about. Might just replace the one under the hood, see if the code cord back, then move on to the rear.
    Thanks again
  7. #7
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,162
    See attached.
  8. #8
    2005_CTS-V's Avatar
    Dec 2012
    Lafayette, IN
    98
    Sweet! Thanks darkman!
  9. #9
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Quote Originally Posted by 2005_CTS-V View Post
    Thanks again
    Hello 2005_CTS-V,
    I am glad to see you have gotten great advice from other forum members. Let me know how everything goes with your vehicle; we want to make sure your concerns are taken care of. If you have additional issues or questions, don't hesitate to ask!
    Sincerely,
    Laura M.
  10. Remove Advertisements
