Where My Oil Go?
Results 1 to 12 of 12
Like Tree9Likes
  • 2 Post By darkman
  • 2 Post By ccorde
  • 4 Post By H-town_V
  • 2 Post By darkman
  • 2 Post By RyRidesMotoX
  • 6 Post By darkman
2004-2007 Cadillac CTS-V General Discussion Discussion, Where My Oil Go? in Cadillac CTS-V Series Forum - 2004 - 2007; Hi guys. I have 06 CTS-V driven it for about 1700 miles then warning low oil message came up on ...
    ccorde is offline Cadillac Owners Member
    Automobile(s): 2006 CTS-V
    Feb 2013
    34
    Where My Oil Go?
    Hi guys. I have 06 CTS-V driven it for about 1700 miles then warning low oil message came up on the screen, had to add 1 quart of oil (5w30 full synthetic), then i had my 1st oil change, 1200 miles later i had to add 1.5 quart of oil. 52000 miles no leak nothing. This engines eat oil for breakfast? I have driven it a little faster then normal a few practice runs 0-60 a few highway passes but nothing like on a track. Engine works good no weird noises. Anybody had a similar issue? please let me know.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,213
  3. #3
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,833
    Re: Where My Oil Go?
    Quote Originally Posted by ccorde View Post
    ... This engines eat oil for breakfast? ...
    Should've gotten an LS6.
  4. #4
    Feb 2013
    34
    Quote Originally Posted by rand49er View Post
    I have 4 years of Extended warranty and why would i want 04 or 05 with LS6? so my warranty would replace rear differential every few month?
    mstrjon32 and mstrjon32 like this.
  5. #5
    ImEpayne is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS-V
    Feb 2013
    North Syracuse, NY
    27
    71
    I have nearly the same story. '06 with 78k. Uses about 1 quart every 3k ish.
    I too have an extended warrenty, I'm wondering if this issue can be determined or fixed under warrenty... I'm just afraid of 6 hours of labor for 'diagnostics' for them to tell me its not covered...
    One thing mine does that often concerns me. Basically cruising at 65 and take it out of gear and brake hard ( Boulder built a highway with stop lights) MASSIVE amounts of white smoke out of the tailpipes. for a good... 3-5 seconds at the stop light. (first time it happened I literally though something was on fire back there). Is this related to my oil consumption or is this an alternate issue...
    ccorde I have also tried the lucas oil treatment stuff and it seemed to prolong the oil consumption but still consuming. From reading the threads Darkman posted I am going to try a 10-30.
  6. #6
    H-town_V's Avatar
    H-town_V is offline Cadillac Owners Fanatic
    Automobile(s): 05 cts-v
    Feb 2013
    341
    Cuz most of us with an ls6 already had the diff replaced with an 06-07 years ago under warranty.
    rand49er, rand49er, pato and 1 others like this.
  7. #7
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,213
    Quote Originally Posted by ImEpayne View Post
    If you switch from 5W-30 to 10W-30 to reduce oil consumption be sure that the high temperature viscosity is actually higher. In case the case of Mobil 1, for example, the 5W-30 has a viscosity at 100 degrees centigrade of 11.0 while the 10W-30 has a viscosity at 100 degrees centigrade of only 10.0. This is not the case however, for every brand.
    ImEpayne and ImEpayne like this.
  8. #8
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    White smoke is coolant, blue is oil, black is fuel (in general). You may have a different issue that needs to be addressed.
  9. #9
    PISNUOFF Guest
    I had this issue with my 418. Ended up being a cracked cylinder sleeve and worn rings allowing excessive crankcase pressure and blowing oil through the PCV system and past the rings.
  10. #10
    Jul 2012
    Wildomar, CA
    31
    976
    Quote Originally Posted by PISNUOFF View Post
    You literally break EVERYTHING at some point. Lol
  11. #11
    carlson_mn is offline Cadillac Owners Enthusiast
    Automobile(s): Platinum 06 CTS-V, kooks, magnaflow
    Jul 2012
    MN
    35
    636
    GM sent a letter out to LS2 GTO owners who had 6 speed manuals explaining this is normal the way the PCV works on our engines when driven with a lot of engine braking or high rpms. I added about 1.2 quart after 7k miles on mine is all though, which didn't bug me much.
  12. #12
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,213
    In the overall scheme of things adding a quart of oil every once in awhile is not that bad - it is not expensive enough to spend a ton of money to eliminate; and adding oil periodically helps keep the additive package in the oil fresh. If you are fouling spark plugs, or mucking up your driveway with leakage the calculus might change, but otherwise I would not worry about it.
  13. Remove Advertisements
