Belt going? Hopefully an easy fix
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, Belt going? Hopefully an easy fix in Cadillac CTS-V Series Forum - 2004 - 2007; OK, so I've got the V up and running good... or so I thought. I got in this afternoon and ...
    Whit151 is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Jul 2010
    St. Charles, Missouri
    31
    OK, so I've got the V up and running good... or so I thought. I got in this afternoon and there was a squeaky belt - didn't think anything of it because it was raining the night before.
    But, I can hear a difference when I would turn the wheel - both when stopped and driving. It sounds like it's straining something, but there is no difference in drive quality. I'm thinking it's a belt, but not entirely sure.
    I turned the car on later on today, and no squeals. Any suggestions as to what it could be?
  2. #2
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Re: Belt going? Hopefully an easy fix
    I would check the condition of the power steering fluid. If it looks either burnt brown (temperature induced deterioration) or milky (moisture) I would change it. I would also change the belt if has much age or mileage. Visual inspection of serpentine belts is problematic.
  3. #3
    Jul 2010
    31
    To add on to this... I got my tires put on today and they told (and showed) me my pressure line hose is leaking - not a lot, but it's starting to go. How hard is this to replace?
  4. #4
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    See attached.
  5. #5
    Jul 2010
    31
    Awesome. Thanks!
  6. Remove Advertisements
