2005 CTS has intermittent starting problems.
Results 1 to 3 of 3
Like Tree1Likes
  • 2 Post By darkman
2004-2007 Cadillac CTS-V General Discussion Discussion, 2005 CTS has intermittent starting problems. in Cadillac CTS-V Series Forum - 2004 - 2007; I am having some starting issues with a 2005 CTS I bought used. Brand new battery. Every once in a ...
    BryanGreen is offline Cadillac Owners Member
    Automobile(s): 2005 CTS
    Apr 2013
    Redlands, CA
    61
    3
    I am having some starting issues with a 2005 CTS I bought used. Brand new battery. Every once in a while you go to start it and nothing happens. All dash lights and radio work. This an intermittent problem. Twice, I had it towed to an auto electric shop after trying to start it for an hour while I was stuck. Both time I called th shop and they said " The tow truck driver started it right up and drove it off the bed, and we can't get it to not start!
    Sometimes I couldn't start it, then an hour or two later I try it and it starts right up and will continue to do so for a few weeks without a problem. Today, not so. Once I moved it into neutral, I heard a strange scraping noise but it started. Today, not so. Then moving the automatic shifter into park, it locked there.
    Anybody have any other ideas? Could a theft sensor be blocking? It kind of acts like it would it if you left it in drive and tried to start it.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,180
    Re: 2005 CTS has intermittent starting problems.
    Assuming it is an automatic transmission, my guess is the starter/solenoid is marginal, or the connections to the starter/solenoid are marginal. If it is manual (this is the CTS-V forum after all) it could also need a clutch position switch adjustment or replacement.
    odla and odla like this.
  3. #3
    Apr 2013
    Redlands, CA
    61
    3
    Oops, I did get in the wrong forum... thanks for answering!
