Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: Woo Hoo, Thank You RevShift. I love my bushings !
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    ^^^ how's that for a title... LOL Whole new car to me.
    Just got my revshift Red rear cradle bushings in along with the Blue diff bushing and CS Diff bushing Block. What a difference. It feels like the car is biting down and grabbing the pavement now. The front end seems to be pulling up more.
    A lot easier / smoother to get her sideways too
    I have a Borla Cat back exhaust, not a whole lot louder than stock when crusing... and I can barely tell a difference in sound from the bushings.
    Other mods are UUC shifter with poly shifter bushings. RevShift trans mount insert, and Trailing arm bushings, and G-Force anti wheel-hop axles. I noticed a little hop one time today, but NOTHING like before.
    Will BMR trailing arms help smooth it out more ?? I'm guessing new better tires will help too.
    Also, Would the Revshift lower shock mount bushings help ??
  2. #2
    D3l7a3ch0's Avatar
    D3l7a3ch0 is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V Black-on-Black
    Nov 2010
    San Antonio
    34
    870
    Re: Woo Hoo, Thank You RevShift. I love my bushings !
    this makes me want those bushings, too
  3. #3
    Mar 2011
    2,045
    You won't feel any difference with the BMR or Killernoodle trailing arms. It's the lower trailing arm bushings that you want (and already have, as noted). Those offer a minor but noticeable stability improvement.
    Revshift doesn't make lower shock mount bushings. Creative Steel does. The most efficient upgrade path for those bushings is to upgrade your shocks. Only the FE4/FG2s have those crappy rubber bushings.
    Better tires will make wheelhop worse.
  4. #4
    Aug 2005
    Northern IN
    1,006
    Quote Originally Posted by FuzzyLogic View Post
    Thanks Fuzzy,
    You get your Revshift bushings in yet ?
    I know the BMR trailing arms get rid of the front/upper rubber bushing on the trailing arm... that won't help ?
    It does have slight noticeable hop, but NOTHING like before. I drifted half way around a loop-d-loop intersection today and so much easier to control now.
  5. #5
    Mar 2011
    2,045
    Quote Originally Posted by SevillianSTS View Post
    I know the BMR trailing arms get rid of the front/upper rubber bushing on the trailing arm... that won't help?
    I've had my bushings since November. Haven't had time to install them because of school and work. Remember this picture?
    While replacing the upper trailing arm bushing probably has some net positive effect on handling, I couldn't tell the difference. And I'm pretty picky.
  6. #6
    DDS rollin a CTS's Avatar
    DDS rollin a CTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V, 2001 Honda Shadow Sabre
    Sep 2005
    Lafayette, IN
    35
    1,641
    ^^^ Yeah that. I just installed 275's (Bridgestone re-11's) all the way around and now the wheel hop is intolerable. If you even think about spinning the tires they start bouncing. I was already planning on getting axles, bushings, and maybe shocks, but now I think I'll have to accelerate that plan. Any recommendations on the most cost efficient yet effective approach?
  7. #7
    Mar 2011
    2,045
    Quote Originally Posted by DDS rollin a CTS View Post
    ^^^ Yeah that. I just installed 275's all the way around and now the wheel hop is intolerable If you even think about spinning the tires they start bouncing. I was already planning on getting axles, bushings, and maybe shocks, but now I think I'll have to accelerate that plan. Any recommendations on the most cost efficient yet effective approach?
    Have you seen the DIY 8.8" build thread on LS1Tech? Bushings will help in the meantime.
  8. #8
    Aug 2005
    Northern IN
    1,006
    Been driving the car for a few days now with the bushings installed...
    In the words of Jay Leno "The drive is more important than the destination"
    Only problem now... being "sideways" is much more easily controlled... gonna cost in tires
  9. #9
    Sep 2005
    Lafayette, IN
    35
    1,641
    No I haven't, I'll have to check that out. Which bushings are the most effective? I've already got the trans mount insert and motor mounts on their way. Do you have to pretty much do all the rear-end bushings to get much improvement, or is there one or two things that have the most impact?
  10. #10
    repenttokyo is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Jan 2009
    1,171
    I just put my Revshift motor mounts, tranny insert, and diff bushing in too, and the difference is astounding. No more clunks, everything is much tighter. Hotchkiss sways are on now too, and once my BFG Rivals get here, I will be ready for the track season!
  11. #11
    barrok69's Avatar
    barrok69 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Maggied
    Mar 2012
    Michigan
    271
    Cradle Bushings + Gforce econo axles + trailing arm bushings = goodbye wheelhop.
  12. #12
    Mar 2011
    2,045
    You'd be insane not to do them all. Each one helps in a different way, and once you've got the subframe out, you're in a good spot to hit everything.
    Here's the DIY 8.8" thread:
    http://ls1tech.com/forums/cadillac-c...ld-thread.html
  13. #13
    Aug 2005
    Northern IN
    1,006
    Quote Originally Posted by barrok69 View Post
    I have new stock motor mounts, I have RevShift Blue motor mounts on the shelf. Will these help with the hop too ?? It still does just a little (but tolerable now.)
    I actually think the car drives smoother now that I have the red cradle bushings in; must have cleaned up some major slop.
  14. #14
    Dec 2008
    377
    I just did red revshift cradle and trailing arm bushings as well as blue MM's and trans insert and the difference is night and day. No comparison!
  15. #15
    Sep 2005
    Lafayette, IN
    35
    1,641
    Thanks thats what I was looking for!
    I'll look into the other bushings too. Purchase price isn't the only issue. I don't have anywhere to work on the car so I'll have to take it to a shop to have it done, so I have to factor in installation cost too. I'll look into the DIY 8.8" but I'm guessing thats beyond the scope of what I'm looking to do to the car for the time being.
  • You may not post replies
