Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Car will not shift in to gear
    Jul 2011
    59
    Got in to car this morning pushed in clutch but car will not go in to gear shut off car out in gear push in clutch start car lurches. With the car running the gears don't grind when trying to put in gear it just will not go in gear. Clutch fluid is full have never had any problems shifting in gears before, any ideas would be appreciated thanks.
  2. #2
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    Re: Car will not shift in to gear
    Sounds like your clutch is not disengaging at all. What year? How many miles? How do you drive it? Previous clutch problems? Is it the OEM clutch?
    Can you get under it to look for a clutch fluid leak? I know you said the fluid was full, but it might give you some hints as to what is going on.
    I don't really know what common failure modes are for hydraulic clutch systems are, but if you are pressing the pedal and the clutch isn't disengaging it could be.
    -No fluid
    -Air in the clutch line
    -Fluid leak or broken line that hasn't drained the reservoir
    -Bad master cylinder
    -Bad slave cylinder
    Goodluck
  3. #3
    Jul 2011
    59
    It is a 07 with about 85000 on the clock I do not know if it is the oem clutch or not I am not the original owner it is my dd I don't drive it real hard get on it once in a while have not showed and signs of clutch failure before now. Find it is that with it running I can't push in to gear can't even force gears to grind
  4. #4
    Nov 2009
    Wisconsin
    33
    785
    Quote Originally Posted by bjazz69 View Post
    I wouldn't try to force it into gear while it's running, you obviously have something wrong, forcing it into gear at this point is just going to do more damage.
    If the only problem that you had was not being able to get it into gear, it could be a transmission problem.
    But when you start the car in gear and it lurches the only cause of that would be that the clutch is not disengaging.
    Call around and find a reputable shop that can diagnose and fix it for you.
    My local Cadillac dealer has a $49 flat rate diagnoses charge. Get it towed to a shop and go from there, my dealer also has free rental cars so you can get to work.
  5. #5
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    The GM transmission trouble shooting chart begins with the magic words - bleed the hydraulic clutch system.
  6. #6
    Jul 2011
    59
    That is what my first step when I get home I was looking for the thread with a picture of the bleeder location do you have a link
  7. #7
    Nov 2009
    Wisconsin
    33
    785
    Don't have a link, but is way up on the driver side.
  8. #8
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Bleed that $hit.
  9. #9
    PISNUOFF Guest
    ^^^^^baleed dat!
  10. #10
    Jul 2011
    59
    Ok gentlemen I open the bleed and nothing comes out push the clutch nothing comes out pumped the clutch nothing comes out any ideas
  11. #11
    Jul 2011
    59
    OK just got finish with the bleed still not shifting
  12. #12
    Nov 2009
    Wisconsin
    33
    785
    Did you get any fluid to bleed out?
    At some point were you able to push fluid out the bleeder by pushing the pedal?
  13. #13
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    See attached.
  14. #14
    Jul 2011
    59
    Yes got it to bleed got good clear fluid didn't see any bubbles
  15. #15
    Jul 2011
    59
    I am hooking a self pump vacuum on the bleeder tube but it is not drawing any fluid through it any ideas
  • You may not post replies
