Another Nav problem Thread.
Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Like Tree6Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Another Nav problem Thread. in Cadillac CTS-V Series Forum - 2004 - 2007; So I've searched the forum and I've found people with similar problems but not the exact problem, so I'm unsure ...
    ImEpayne is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS-V
    Feb 2013
    North Syracuse, NY
    27
    71
    So I've searched the forum and I've found people with similar problems but not the exact problem, so I'm unsure how to go about the fix.
    I have an '06 V with Nav that has the DVD logo. When I load the Nav disc it prompts me to choose a language at the warning screen or what not. I click accept and this is where it freezes. Only once has it began to load the map, which was just glitchy squares not resembling a map.
    Also, I can watch DVD's just fine and it actually reads scratched DVD's pretty well.
    So after surfing the forum board, I am unsure if this is firmware issue, a Nav CD issue. Ontop of that I've seen threads of certain places to buy newer CD's, who to contact, what version to get...
    Information overload and not sure which way to go.
    Thanks,
    Eric
  2. #2
    silentwig's Avatar
    silentwig is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    May 2012
    MD
    32
    111
    Re: Another Nav problem Thread.
    I had the exact same problem. The radio is finicky with the map dvd. Even though the disc looks clean, mist it with cd/dvd cleaner and wipe it dry with those fine fiber cloths the the ones that come with sunglasses or phone case kits. It should work after that.
    And yeah, I tried the old dvd video method and it worked fine, but the map dvd didnt work till i cleaned it as explained above.
  3. #3
    Feb 2013
    North Syracuse, NY
    27
    71
    Thank you! Will try that today.
  4. #4
    mike6466 is offline Cadillac Owners Member
    Automobile(s): 2006 cts v
    Jun 2012
    28
    43
    Mike won't read my nav disc or DVDs. One day it all just froze and never worked again. I would hate to spend all that money to find out I could have fixed it myself or have someone fix it cheaper.
    Any suggestions
  5. #5
    D3l7a3ch0's Avatar
    D3l7a3ch0 is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V Black-on-Black
    Nov 2010
    Los Angeles
    34
    904
    I wonder if the drive can be modded to accept a disc ISO on a USB.
    sorry, just thinking out loud.
    I'll ask the housemates this afternoon. they should know pretty quickly if
    there is any compatibility that would allow this.
    I'm just thinking, maybe there's a USB reader that will go into a SATA or
    PATA connector, which optical drives most commonly are.
    ...and have nothing but the disc contents on the USB.
    (USB storage capacities weren't big enough for this to be viable even
    through 2006 when the last V1s were sold...)
    if the optical drive is anything relatively "off-the-shelf," there's a chance this
    just might potato.
  6. #6
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,790
    Sometimes the drive just coughs and pukes.
    I might have an extra DVD drive.
    The drive connectors (thanks Delco for nothing) are not standard.
  7. #7
    Feb 2013
    North Syracuse, NY
    27
    71
    I haven't tried using disc cleaner yet. It's surprisingly hard to get CD cleaner nowadays... Office Max told me to try GameStop (some videogame store). Will update once I try that.
  8. #8
    D3l7a3ch0's Avatar
    Nov 2010
    Los Angeles
    34
    904
    Quote Originally Posted by heavymetals View Post
    according to my roommate:
    2 options for updating or replacing the optical drive:
    replace the internals with a new laser (most likely source of problems in an optical drive)
    -or- (and I would love for this to work)
    use a SATA to IDE/PATA adapter and use an SSD (or regular hard drive *yuck*).
    it would require a converter/adapter from SSD to whatever connector the optical drive uses, hopefully IDE... but
    is there any chance it is this or something like this (slim cd connector, there is also a slightly larger version):
    larger version:
    adapted to IDE via:
    (but the other way around->SATA to IDE to Slim CD)
    if it is, then the last obstacle is whether the NAV disc is not encrypted and has regular folders if you put it into your computer DVD drive (does it display a normal-looking/regular file tree)
    I already have an iso (somewhere on one of my hard drives) and the nav disc (somewhere else but I can't remember where, exactly)
    //////if this works then everyone owes me a dollar
  9. #9
    Destram's Avatar
    Destram is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Mar 2013
    Florence, AL
    27
    40
    When I bought my car a couple months ago, it didn't come with a nav DVD, so I ordered a version 6.0 off eBay (I don't know what the newest version is. That's all I saw on eBay). When I received it, I had the exact same problem you're having. The screen was glitchy when it actually did stop freezing after you select the language. I sent it back for a refund and ordered another one exactly like it from a different seller on eBay, and it's worked fine from the beginning. Maybe you just have a bad disc and it isn't the unit after all. Just a thought.
  10. #10
    Feb 2013
    North Syracuse, NY
    27
    71
    D3l7a3ch0 I'm afraid I have no idea what any of that means? Are you talking about being able to burn the nav info onto a disc? I'm sorry... all those acronyms...
    Destram Good to know. So is the 6.0 pretty well updated and how much did you end up spending for one on the Bay.
    D3l7a3ch0 and D3l7a3ch0 like this.
  11. #11
    D3l7a3ch0's Avatar
    Nov 2010
    Los Angeles
    34
    904
    put the contents of the nav disc (and nothing but the nav disc) on a laptop hard drive (known as Solid State or SSD)
    and then with the use of adapters, plug everything in at the connector the DVD used
    the head unit will not know the difference. point of failure removed (also faster read times)
    ImEpayne and ImEpayne like this.
  12. #12
    Destram's Avatar
    Mar 2013
    Florence, AL
    27
    40
    Quote Originally Posted by ImEpayne View Post
    Sorry for the late reply. I'm not sure how updated 6.0 is. I've run into a couple problems where it took me to places that didn't exist in that location anymore, but I've also had it take me right where I wanted it to. I think I ended up paying ~$160 for the 6.0 disc on eBay. If you find out your disc is the problem, you can get one on eBay, or if you want to make sure you get the most up to date disc, I know they're $300 at the dealership (at least that's how much they are at my dealership).
  13. #13
    D3l7a3ch0's Avatar
    Nov 2010
    Los Angeles
    34
    904
    if the hard drive thing works, you can download the ISO and load the contents of the disc onto the drive (and do it that way)
    I really need to just open it up again, especially since I can't find a picture of the cts dvd drive
    //apparently the nav disc uses non-encrypted root directory. the hard drive can be made to do this as well
    http://www.cadillacfaq.com/faq/answe...-structure.pdf
    *for near-future reference
  14. #14
    Feb 2013
    North Syracuse, NY
    27
    71
    If whatever you are talking about works. And it's easy. Count me in.
  15. #15
    D3l7a3ch0's Avatar
    Nov 2010
    Los Angeles
    34
    904
    yeah, if it works at all it will work very simply.
    hey, are you willing to open up your nav unit and replace the DVD drive? if you feel comfortable doing that, we could swap out 1:1, or you could send me yours so I can change out the laser and send it back to you.
    that's not a promise *yet* ...I'm just throwing an idea out there. to see what people are comfortable with.
    I don't use my nav, so I'm thinking I could just... use mine as an extra core and continuously swap out drives I receive with one that has a new laser.
    I ... hereby commit to pull my nav center out tomorrow. and also try the hard drive thing (or see what the situation is, inside the tin case of the nav unit
    there's a chance the dvd drive uses a ribbon rather than a conventional cable,
    bleh yeah lemme know
    //4PM pacific, radio is pulled. working on it at my desk now. I will keep this thread poasted.
    //5PM: welp, there is one ribbon that goes to the laser, and another ribbon that goes to the motor--that was expected
    but there are two ribbons going from the drive to the rest of the nav circuit board, and I need to ask my roommates and the internet (lol) how they're different from older optical drives
    these are the screws, (not too scary) and I've highlighted the assembly that houses the laser. I'm pretty sure the laser can be replaced after opening the highlighted body, but I want to check with my roommates before doing it.
    the metal housing of the nav unit comes apart without bending anything permanently... there are small metal and plastic tabs that hold it all together. (zero commitment)
    see ya tomorrow... my roommates don't get back til late tonight... there's some type of event in Santa Ana they are attending.
    also: Conan O'Brien is hosting the Presidential Roast tonight, 9:45 Eastern
  16. Remove Advertisements
