Oxygen sensor Smog fail - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
Like Tree5Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Oxygen sensor Smog fail in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by liqidvenom Brian could break Wolverine ...nothing can survive him. What cruise this weekend? I live out in ...
  1. #31
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Quote Originally Posted by liqidvenom View Post
    What cruise this weekend? I live out in Long Beach
    Its near Temecula, Ca. Check the Southern California thread I posted up a link there. I'm on my phone now so I don't have easy access to the link.
  2. #32
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    Re: Oxygen sensor Smog fail
    My car has Jersey plates on it....most likely wasnt me.
  3. #33
    jonathan2169's Avatar
    jonathan2169 is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V and 2004 CTS-V
    Apr 2013
    40
    84
    UPDATE: So we finally passed smog. It was the O2 sensors (both banks) and both were paid by the dealer.
    So now we roll into some DIY fixes. I am a few steps into replacing the Steering Wheel Position Sensor (thanks to the awesome step-by-step by CancerJCC on these forums!). Motor mounts, differential bushing and trans mount inserts are en route from Revshift. And as soon as I can isolate the intermittent coolant leak that will be next on the hit list.
    Anyways really stoked that the car is legal and looking forward to getting it running smooth!
  4. #34
    PISNUOFF Guest
    Quote Originally Posted by Bacon V View Post
    No, but i just put some in this weekend...what are you gonna tell me is wrong with them?
    The exact same thing that happened when CS started making motor mounts.
    So ALL of my experiences with damaged parts should be discounted? I'll just stop relaying my experiences.
    Quote Originally Posted by D3l7a3ch0 View Post
    PISNUOFF managed to liberate the cores from their repressive polyurethane shells. with the motor. I'm not worried about mine, I'm pretty sure his ...conditions are unique. revshift has updated their motormount cores since/as a result iirc
    I seriously doubt I will be the only one. I'll bet my paycheck on it.
    Quote Originally Posted by jonathan2169 View Post
    I'm glad it was simply sensors and you didn't just start randomly swapping cats.
  5. #35
    D3l7a3ch0's Avatar
    D3l7a3ch0 is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V Black-on-Black
    Nov 2010
    San Antonio
    34
    869
    so let it be written, so let it be done
  6. #36
    D3l7a3ch0's Avatar
    Nov 2010
    San Antonio
    34
    869
    b-b-b-b-bump
    PISNUOFF I was sitting in physics class and it occurred to me why you are causing otherwise high-rated parts to fail
    when you tighten everything up, the force is applied in a shorter period of time, which makes the impulse bigger. The ratings you're going by are meant for systems that have more "give".
    ...to put it simply. (hitting a brick wall vs a rubber wall concept).
    so even with relatively near-stock 500ish hp (iirc you have), you're using your products in a way that was not intended/beyond what they were engineered for. the power numbers are for more conservative bushings/diff/axles etc.
    I... remain confident in my motor mounts
    I should have an engine-to-strut tower brace sometime in the... near future that would alleviate your motor mount issues. holding all that power at two points on the sides of the block isn't the best solution for a rotating force. it's good for stock numbers, but definitely could be better.
    not sure who I will get to weld it (aluminum). I also have to calculate/find an appropriate off-the-shelf bushing to use between the motor bracket and strut tower brace. (size and material to match the stiffness of "80" and "95" for the torque at a longer lever-arm............)
    you might break something else, though.
  7. #37
    Feb 2009
    Long Beach Ca
    35
    2,741
    He is driving his sports sedan in the manner it is supposed to be driven. These cars just tend to break.
  8. #38
    D3l7a3ch0's Avatar
    Nov 2010
    San Antonio
    34
    869
    so... stock? heh
  9. Remove Advertisements
