noise still coming from the back...need help.
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Like Tree1Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, noise still coming from the back...need help. in Cadillac CTS-V Series Forum - 2004 - 2007; I changed my differential oil like I was told I should but the same rubbing type of noise in the ...
    4DoorZ06's Avatar
    4DoorZ06 is offline Cadillac Owners Member
    Automobile(s): 05 CTS V & 08 CTS 4
    Mar 2013
    San Jose, ca
    23
    I changed my differential oil like I was told I should but the same rubbing type of noise in the back of the car is still there. Is there anyone who knows what this could be?
    Also my front left shock is going out. I need to know wich front shocks would be good to put on without breaking the bank too much.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    Re: noise still coming from the back...need help.
    I would put OEM FE4 shocks on the front.
    As to the rubbing sound we need more information as to what it sounds like and under what conditions it occurs.
  3. #3
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,815
    As darkman mentioned, is that "rubbing" coming only when you're turning? ... or going straight? ... or any motion at all?
    I'm assuming you've looked under there to make sure there isn't some branch dragging under there or a piece of cardboard caught in the wheel well.
  4. #4
    Bacon V's Avatar
    Bacon V is offline Cadillac Owners Fanatic
    Automobile(s): '04 CTS-V
    Jul 2012
    33
    107
    Rubbing as in metallic? Could be anything from a rotor dust shield dragging on the rotor to the differential whining. The diff in these cars is known to whine at times - you can reduce it with certain lubes but others will not change it. Could be the diff as you suspect and you might need a different weight and/or additive to reduce it. Could also be brakes dragging or rubbing on a corroded rotor edge. Can you jack up the rear and rotate the wheels by hand to see if you can reproduce it?
  5. #5
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    Can you describe the ruckus?
  6. #6
    4DoorZ06's Avatar
    Mar 2013
    San Jose, ca
    23
    The noise is only when I am turning and in gear. It does not make the noise while turning in neutral nor when im going straight just when turning and in gear. It just sounds like metal and plastic rubbing if it makes sense.
  7. #7
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,815
    Your description sounds like the slip-lock additive wasn't added when the differential fluid was changed.
    HAMSTAR and HAMSTAR like this.
  8. #8
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by rand49er View Post
    Agree.
  9. #9
    4DoorZ06's Avatar
    Mar 2013
    San Jose, ca
    23
    So I took it to my mechanic and he said the clunking is caused by the motor mounts. Are the UMI motor mounts any good? The complete kit goes for $249
  10. #10
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,815
    Quote Originally Posted by 4DoorZ06 View Post
    ... rubbing type of noise in the back of the car is still there ...
    ... the clunking is caused by the motor mounts ...
    That could well be, but did you get the first problem solved?
  11. #11
    Bacon V's Avatar
    Jul 2012
    33
    107
    Quote Originally Posted by JDB View Post
    lol, havent seen a breakfast club quote in a while
  12. #12
    J W
    J W is offline Cadillac Owners Enthusiast
    Automobile(s): CTS /CTS-V / Escalade EXT / Coupe
    Jun 2009
    583
    Mine has been sitting all winter. I brought it out yesterday and while driving i would hear a clunking sound when shifting It did not do it all the time but i did notice the sound. Could that be the motor mounts. It has 41k on it.
  13. #13
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by J W View Post
    It could be the motor mounts, but there are other possibilities. The differential bushing would be my first guess. The motor mounts are liquid-filed units and leak brown/rust color fluid when they have failed. You could look for leakage with the car on a rack or jack stands.
  14. #14
    J W
    Jun 2009
    583
    Ok thanks, I'll lift it tonight and see if there's any leakage. If it's the differential bushings would there be a way to tell.
  15. #15
    Bacon V's Avatar
    Jul 2012
    33
    107
    Yes, you can usually push up hard on the bottom of the diff and get it to move a good amount if it's failed. You can also sometimes see rubber chunks missing and/or hanging out
  16. Remove Advertisements
