Running a little Sluggish.... Ideas?
Results 1 to 9 of 9
2004-2007 Cadillac CTS-V General Discussion Discussion, Running a little Sluggish.... Ideas? in Cadillac CTS-V Series Forum - 2004 - 2007; Hey Guys. New to the V world but am loving the car so far. In the last few days I ...
    aggierichie is offline Cadillac Owners Member
    Automobile(s): 2004 CTS - V
    Feb 2013
    35
    13
    Hey Guys. New to the V world but am loving the car so far. In the last few days I have noticed a bit of a lag around 3000 RPMs and it is when i am gradually accelerating. I notice it in 3rd and 4th gear. It honestly feels like carb issues where there is a slight lag then smooth and just doesn't accelerate as smooth as it should. This is VERY slight and you probably wouldn't notice it unless you were really focusing on it.
    Based on what I know it sounds like it could be an injector or plugs but it is not throwing any codes. I wanted to throw this out there to see if anyone had any other ideas. The car has 78K miles on it and was owned by an old guy previously so the odds of it having a tune up i believe are slim. I am going to do the plugs this weekend but if you have any thing to add i would really appreciate it.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,179
    Re: Running a little Sluggish.... Ideas?
    Typically you would have a Check Engine Light and a code in the computer to indicate some fault if the problem is serious.
    Make sure you are running high octane fuel.
    If you replace the plugs I would also replace the plug wires. The OEM wires are good enough. If you are on a tight budget you can check the current wires with a multimeter. The maximum acceptable resistance is 1,484 ohms.
    Make sure the air filter is fresh.
    You could also check the fuel pressure at the schrader valve on the fuel rail. The spec is 55-62 psi.
    Beyond that, I would wait for a Check Engine Light.
  3. #3
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    Darkman has a bunch of good suggestions.
    Has the fuel filter been replaced? If it has not, or you aren't sure, toss a new fuel filter in and see if that fixes it.
  4. #4
    SevillianSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V
    Aug 2005
    Northern IN
    1,006
    Could throw some SeaFoam or Lucas Fuel system cleaner in the gas tank.
  5. #5
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by darkman View Post
    Darkman always has great suggestions, but I would bet this^
  6. #6
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,365
    we have a serviceable fuel filter?
  7. #7
    Aug 2005
    Northern IN
    1,006
    Quote Originally Posted by odla View Post
    Yep, changed mine.
  8. #8
    Nov 2009
    Wisconsin
    33
    785
    Yes. If memory serves it is just in front of the driver side rear wheel well. Standard quick disconnect fuel line tools are needed, but it's about a 20-30min job to replace.
  9. #9
    izcain's Avatar
    izcain is offline Cadillac Owners Fanatic
    Automobile(s): Without a caddy
    Jan 2013
    Port Angeles
    174
    I think this is the best and would probably help out alot!
    You have to have a good base to go off of before diagnosing anything anyways!
    If you performed each of these suggestions you will probably come across something that stands out as you are going thru them I bet!
  10. Remove Advertisements
