Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: Ticking from the front of the motor...
    ctsvdubbz's Avatar
    ctsvdubbz is offline Cadillac Owners Fanatic
    Automobile(s): 05 cts-v
    Jan 2011
    williamsport pa
    33
    103
    Checked everything up top.. Header bolts, rockers, coils,... Ticking seems to be coming from the front.. Put a stethescope right behind the crank pulley.. Seems to be real loud right there.. Could it be a timing chain issue cuz i was leaning towards that and plan to change it.. But just wanted some input see if anyone else had any ideas...
  2. #2
    Litlgangsta is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS 3.6 w/Bose
    Oct 2012
    Surrey. BC
    24
    101
    Re: Ticking from the front of the motor...
    *bump* I to have this problem and would like to hear some opinions.
  3. #3
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    Geez, those timing chains last well past 100k miles unless they're driving a very serious camshaft at very serious RPMs.
    How many miles do you have?
    Could it also be one of the front rods (loose cap)? Can you post up a vid with audio?
  4. #4
    ctsvdubbz's Avatar
    Jan 2011
    williamsport pa
    33
    103
    I will post a video.. Last summer i let my little brother take it for a day.. Came back with a broken valve spring and a slightly bent valve... Im thinking maybe a bent pushrod also? Would that tick? All the work was done by a machine shop n changed everything in the head except pushrods...
  5. #5
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,207
    Quote Originally Posted by ctsvdubbz View Post
    Yes, a bent pushrod can cause a tick.
  6. #6
    Aug 2012
    gay
    184
    Quote Originally Posted by darkman View Post
    i agree, but not in this location. i think what he is hearing is likely a bearing in an accessory drive pulley/tensioner pulley.
    i can't envision a scenario in which an impending timing chain failure would make a ticking sound.
  7. #7
    D3l7a3ch0's Avatar
    D3l7a3ch0 is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V Black-on-Black
    Nov 2010
    San Antonio
    34
    870
    would you say it's more of a tickticktick tick tick ticktick or more of a tick ticktick tick tick ticktick
    there's a little bitty change...it's not the same, that little bitty "ting"
  8. #8
    Aug 2012
    gay
    184
    delta, it could be the rear end. he might need some octane booster to get it figured out for sure.
  9. #9
    ls6v is offline Cadillac Owners Member
    Automobile(s): 2004 cts-v
    Aug 2012
    Fargo, ND
    64
    mine ticks and I only have 8700 miles on my 04, especially when the motor is cold, is this a common thing or should I be pooping? its like a mild lifter tick sound
  10. #10
    D3l7a3ch0's Avatar
    Nov 2010
    San Antonio
    34
    870
    for real, though, robojesus, I think he should try a speed density tuen
  11. #11
    ctsvdubbz's Avatar
    Jan 2011
    williamsport pa
    33
    103
    Took off the main belt... Still ticked.. Used a stethoscope.. I know they arent always 100 percent accurate... Seems reql loud on the bottom right below the crank pulley..
    Definitely right in the front...
  12. #12
    Aug 2012
    gay
    184
    crank or rod bearing maybe!?!?!
  13. #13
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    Seems like a bearing would be more of a pronounced knock instead of a tick.
    Where's that video?
    And the cold ticking is most likely piston slap which is somewhat common on yhe ls6 when the motor is cold.
  14. #14
    D3l7a3ch0's Avatar
    Nov 2010
    San Antonio
    34
    870
    is that where the oil pump is located
  15. #15
    ctsvdubbz's Avatar
    Jan 2011
    williamsport pa
    33
    103
  • You may not post replies
