Ticking from the front of the motor... - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Like Tree3Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Ticking from the front of the motor... in Cadillac CTS-V Series Forum - 2004 - 2007; I have recently retired from noise diagnosing through the internet, but good luck with your search. my recommendation is, until ...
  1. #16
    D3l7a3ch0's Avatar
    D3l7a3ch0 is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V Black-on-Black
    Nov 2010
    San Antonio
    34
    870
    Re: Ticking from the front of the motor...
    my recommendation is, until you know what part you have to pull, take it to a mechanic on-the-clock or otherwise, so they can run diagnostic actions in person
    may you continue to work hard in your endeavors, brother.
  2. #17
    ctsvdubbz's Avatar
    ctsvdubbz is offline Cadillac Owners Fanatic
    Automobile(s): 05 cts-v
    Jan 2011
    williamsport pa
    33
    103
  3. #18
    ctsvdubbz's Avatar
    Jan 2011
    williamsport pa
    33
    103
    Any ideas?
  4. #19
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    In your first post you listed rocker as one of the things you had already checked. Have you had both valve covers off?
  5. #20
    ctsvdubbz's Avatar
    Jan 2011
    williamsport pa
    33
    103
    Yes i torqued all the rockers.. And had both valve covers off..
  6. #21
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    I couldn't here anything all that unusual on the video. I know I here more noise with my engine cover off, which is one of the reasons GM puts them on there. You might see what it sounds like with engine cover on.
    Also if you can put it on Rhino ramps or jack stands and get under the car with a stethoscope any rod or main bearing noises will be louder on the bottom side of the motor. How is your oil pressure?
  7. #22
    ctsvdubbz's Avatar
    Jan 2011
    williamsport pa
    33
    103
    Oil pressure reads real high.. Think it may be broke... Been that way since i got it... Used a stethoscope seems to be coming from the bottom right in front of the crank pulley...
    A bearing would be a knock id think.. And theres no shavigs of metal in the oil..
  8. #23
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    The sound of a spun main bearing is more of a metallic squeal than a knock - very ugly sound. The rod bearing, of course is a knock. The typical way to check the oil for metal is to cut open the oil filter.
  9. #24
    D3l7a3ch0's Avatar
    Nov 2010
    San Antonio
    34
    870
    Quote Originally Posted by darkman View Post
    all the oil filters I cut open have shavings in them like I just hacksawed through metal! help! (and some of it is even the same color as the paint on the outside of the filter--help!!)
  10. #25
    sssnake's Avatar
    sssnake is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Dec 2008
    Huntsville
    49
    291
    When you took the valve covers off did you check all of the pushrods (roll them on a clean flat surface)? I couldn't here anything with the rpms up but at the end of the clip I thought I heard a familiar tick. If the pushrods are slightly bent it reduces preload and makes the valve train noisy among other issues.
  11. #26
    ctsvdubbz's Avatar
    Jan 2011
    williamsport pa
    33
    103
    Did not check the push rods that could also possibly be... Everyone ive talked to says its lifters or something top end.. Which kinda makes me a little less worried... But i will check them and price lifters and maybe rockers n just replace it all... The stethoscope was loud right behind the crank pulley... So that worried me alot..
  12. #27
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    For what it is worth a failing harmonic balancer can become noisey even without developing any visible wobble.
  13. #28
    ctsvdubbz's Avatar
    Jan 2011
    williamsport pa
    33
    103
    Swapped the pushrods... Tick is gone... Some of the pulleys are a little noisy still but sounds 100 times better... Found one pushrod that was bent.. Not by much at all... Cant believe a bens that slight would cause a tick like that..
  14. #29
    sssnake's Avatar
    Dec 2008
    Huntsville
    49
    291
    Quote Originally Posted by ctsvdubbz View Post
    Be sure the lifters and cam are ok. With a bent pushrod you may find damage to them as well.
  15. Remove Advertisements
