Help! Stripped Motor Mount Bolt! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
2004-2007 Cadillac CTS-V General Discussion Discussion, Help! Stripped Motor Mount Bolt! in Cadillac CTS-V Series Forum - 2004 - 2007; Silly question.... you took the weight off of the mounts/brackets, by jacking up the motor, right? CRC Freeze Off?...
  1. #16
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    Re: Help! Stripped Motor Mount Bolt!
    CRC Freeze Off?
  2. #17
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    I took the weight off the mounts by jacking up the motor from the forward edge of the oil pan (where it's the strongest). Never tried freeze off.
  3. #18
    Bacon V's Avatar
    Bacon V is offline Cadillac Owners Fanatic
    Automobile(s): '04 CTS-V
    Jul 2012
    33
    107
    not sure if it would reach, but you could try an extra long (12-18") drill bit and maybe an extender to drill the head off the bolt. Chances are you wouldnt get the stud out afterwards, but whats worse, running 3 bolts on both drivers side and passenger side, or two different MMs?
    Something like this:
    http://www.homedepot.com/p/Klein-Too...6#.UVsxDpOG01g
    Coupled with this:
    http://www.globalindustrial.com/p/to...FY1aMgodZDkAqw
  4. #19
    Mar 2011
    2,045
    Quote Originally Posted by Bacon V View Post
    Thanks for the tip--I'll see what I can do.
    As a quick thank you to those of you who helped, I snapped a quick pic when the sun popped out:
    Filthy as it is, it's amazing how hard it is to make these cars look bad. Also, even with one Creative Steel motor mount, the throttle response is significantly better. Much crisper, although I'm definitely feeling some NVH due to its 87A hardness. When/if these mounts crap out, I'll definitely switch to 80A Revshift motor mounts. Shame that they didn't pay a bounty for their competitors' products.
    Also, I installed the Addco 2290 front sway bar--it's a BEAST. Coming from the Hotchkis sway bar (which is already pretty stiff), I was impressed by how super flat the body stayed through 1 G+ corners. Unfortunately, the clearance between the Addco 2290 and the FG2 shock body is nearly zero. Here's to hoping that the KW Variant 3 shock body isn't thicker. If it is, I'm going to have to go back to the Hotchkis.
