Cruise control inop
Results 1 to 15 of 15
Like Tree1Likes
  • 2 Post By darkman
2004-2007 Cadillac CTS-V General Discussion Discussion, Cruise control inop in Cadillac CTS-V Series Forum - 2004 - 2007; Someone must know what the computer needs to see to allow the cruise control to function. I have 12volt power ...
    c.griggs is offline Cadillac Owners Member
    Automobile(s): 2005 cts=v motor and 6 speed in 91 rx7 convert
    Aug 2012
    7
    Question2005 cts-v cruise control inop in my rx7
    Someone must know what the computer needs to see to allow the cruise control to function. I have 12volt power to the clutch pedal position sensor, the extended travel brake pin, and 12 volts to the cruise on pin. I also have the Mazda cruise stalk
    Wired for 12 volt input to set-accl and decel-resume. The dbw is working fine, no codes, what am I missing? Help
  2. #2
    CTSV_Rob's Avatar
    CTSV_Rob is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2007 CTS-V Thunder Gray; 2004 Cowboy Cadillac (SRT10)
    Mar 2007
    Sunny CA.
    50
    17,678
    Re: 2005 cts-v cruise control inop in my rx7
    I would recommend asking this in the 2004 - 2007 General Forum. You will probably not get a reply in here.
  3. #3
    Aug 2012
    7
    QuestionCruise control inop
    I have a ls6 from a 2005 cts-vin my rx7 convert. It has dbw and the cruise is wired properly. There is 12 volts to the cruise on, the cpps, the extended brake travel, and available for set, resume, coast, and accelerate. What else do I need to get this to work? HELP!!
  4. #4
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,165
    Re: Cruise control inop
    There are some attachments pertaining to cruise control that may help found in this thread: http://www.cadillacforums.com/forums...so-serves.html
  5. #5
    mstrjon32 is offline Cadillac Owners Enthusiast
    Automobile(s): NONE
    Oct 2010
    Mainz, Germany
    788
    I can't help you with the cruise problem, but I would like to see some pictures of your car.
  6. #6
    Aug 2012
    7
    Thanks for the response, but all these issues check out ok. Do you suppose that the computer needs a abs signal of some kind? 0 to 5 volts, 12 volts, or 50 ohms to ground? C.griggs
    Coming when I figure out how. C.griggs
  7. #7
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,165
    See attached.
    c.griggs and c.griggs like this.
  8. #8
    Aug 2012
    7
    Thanks, the description and operation is most helpful. You are a great source of technical info and your help is really appreciated. By the way, this conversion in my 3100 lb rx7 convert really accelarates. C.griggs
  9. #9
    Aug 2012
    7
    Another thing, would you have a diagram of the abs schematics? Maybe the 5371 circuit needs to be open or12 volts. Thanks, c.griggs
  10. #10
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    LS6 in a light car...who would be setting cruise control??
    In 20+ years of driving, I can count on 1 hand the number of times I've used cruise control. Too many left lane squatters around here to even use it.
  11. #11
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,919
    Correct - Site Rules and Regulations has nothing to do with cruise control operation. See post #2 in here - carryover from merged threads.
    Moved to the proper CTS-V area.
  12. #12
    CTSV_Rob's Avatar
    Mar 2007
    Sunny CA.
    50
    17,678
    Quote Originally Posted by JDB View Post
    I would to keep from doing 90+ all of the time.
    I use my CC a bit more often than that
  13. #13
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,165
    Quote Originally Posted by c.griggs View Post
    See attached.
  14. #14
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    Not sure if it's been covered but clutch position sensor? I've had occasional issues because of mine.
  15. #15
    CTSV_Rob's Avatar
    Mar 2007
    Sunny CA.
    50
    17,678
    ^^ lol, great point. That's what caused mine to stop working for a short period.
    You may want to consider this.
    http://www.cadillacforums.com/forums...e-manuals.html
  16. Remove Advertisements
