Engine hot ac off
Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By gruvent
2004-2007 Cadillac CTS-V General Discussion Discussion, Engine hot ac off in Cadillac CTS-V Series Forum - 2004 - 2007; Engine hot ac off error message on DIC. Comes up as soon as the car starts ( even if the ...
    gruvent is offline Cadillac Owners Member
    Automobile(s): 2006 CTS-V
    Jul 2012
    Merritt Island, FL
    51
    Engine hot ac off
    Engine hot ac off error message on DIC. Comes up as soon as the car starts ( even if the car is cold). Temperature gauge reads nothing, and digital temperature reads - - -
    From what I read on here it could be:
    1) thermostat 2) sending unit 3) reset computer.
    Where should I start?
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,181
    Re: Engine hot ac off
    Quote Originally Posted by gruvent View Post
    3-2-1
    Resetting the computer is free - disconnect battery for 30 minutes.
    Sending unit is the most likely - they don't cost much. GM Part Number 15326388
    Thermostat is unlikely since it is not in play when you start the car.
    It also could be oxidation on Ground 101, or other grounds in the engine compartment - see attached.
  3. #3
    Jul 2012
    Merritt Island, FL
    51
    Thanks darkman, that makes sense. By chance do you know where the sending unit is on the LS2? (2006)
  4. #4
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    I don't know with certainty. I assume that it is located on the driver's side cylinder head at the front. The LS2 and the LS6 have the same cylinder heads.
    Supplement: Rock Auto shows the part number for the LS2 and LS6.
  5. #5
    pato is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V
    Aug 2011
    186
    ^^ That is correct. The coolant sensor is next to the exhaust port for cylinder 1 (driver's side head).
  6. #6
    Jul 2012
    Merritt Island, FL
    51
    For the record, The Computer reset did not work, came back on shortly after the reset.
    However,I did unplug the sensor wire (at the sensor) and plugged it back it and the problem went away. So it's possible that the contacts just need to be cleaned.
    Thanks!
    HAMSTAR and HAMSTAR like this.
  7. Remove Advertisements
