Brake lights
Results 1 to 8 of 8
2004-2007 Cadillac CTS-V General Discussion Discussion, Brake lights in Cadillac CTS-V Series Forum - 2004 - 2007; I noticed I had a burnt out brake light bulb. No problem, changed both top bulbs and then realized the ...
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    Brake lights
    I noticed I had a burnt out brake light bulb. No problem, changed both top bulbs and then realized the other two bulbs were not working. Today I replaced all the bulbs and I only have the top driver side brake light working. All of the tail lamps work, its just the brake lamp that is not. I checked fuses but am scratching my head why only one bulb works for brakes and all work for tail lights. Any thoughts?
    Do the center bulbs work as the brakes also or just tail lamps. ( all three on each side have 3157 bulbs)
  2. #2
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    Re: Brake lights
    Wut?
  3. #3
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    The bottom tail light. Is it a brake light also or is it just a tail light? There is a 3157 dual filament bulb in there now.
  4. #4
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,372
    Re: Brake lights
    Make sure that the bulb is in the socket correctly. Mine did the same thing. I had to make sure it was all good.
  5. #5
    JDB's Avatar
    JDB
    Apr 2010
    PA
    1,070
    Re: Brake lights
    Only the top light is a brake light.
  6. #6
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    Thanks. I figured only the top was the brake light however the lower does have three wires going into the plug.
  7. #7
    JDB's Avatar
    JDB
    Apr 2010
    PA
    1,070
    Re: Brake lights
    the one for the turn signal? if so, it's hazard as well.
    I have found the signals in this car is some of the oddest wiring evAR!
  8. #8
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    No. There are three bulbs ( 4 if you count the 194)per side. both the middle and top are three wire and the bottom (turn signal) is a two wire.
  9. Remove Advertisements
