Need specific advice
Results 1 to 8 of 8
2004-2007 Cadillac CTS-V General Discussion Discussion, Need specific advice in Cadillac CTS-V Series Forum - 2004 - 2007; Hey, guys. I'm going to turn in 2003 3.2 CTS-V. To do this, I'll buy some broken CTS-V and change ...
    sandalet's Avatar
    sandalet is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-2003, 3.2 automatic
    Nov 2011
    Chechnya, Grozny-City
    39
    620
    Hey, guys. I'm going to turn in 2003 3.2 CTS-V. To do this, I'll buy some broken CTS-V and change it to the engine, gearbox and other parts of the CTS-V. I can not buy ready-V, because in my country is very high import duties on a large number of engines. My question is, what are the common parts of my V and 3.2? Suspension, manual transmission, drive shafts the same? Can I leave the wiring in the cockpit, or need to be replaced? ...
  2. #2
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,391
    Re: Need specific advice
    The suspension and chassis are the same (different dampers, springs, and anti-roll bars, but the control arms, crossmembers, mounting locations, etc are all the same).
    I would guess the interior wiring is largely the same. The V came with some added features that the V6s didn't have, but I don't know how much of that is needed to run the V's engine.
    Transmission is different - the V uses a Tremec T56 6-speed. Even the V6s that have a 6-speed don't use the Tremec.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  3. #3
    sandalet's Avatar
    Nov 2011
    39
    620
    Delete
  4. #4
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    I'll close. Contact me if anything.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
  5. #5
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    Reopened
    [2006 CTS-V]
  6. #6
    HAMSTAR is offline Cadillac Owners Enthusiast
    Apr 2012
    Seattle, WA
    731
    No offense to this board, but this seems like the type of very technical information that is more readily available on LS1tech. OP, I suggest you post your question there: http://ls1tech.com/forums/cadillac-cts-v-68/
  7. #7
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    Quote Originally Posted by HAMSTAR View Post
    Seems same people post in both forums.
    Either way... this would be a big job, you'd need the entire engine cradle, engine, all harnesses, ECM, driveshaft, diff, axles, etc etc etc from a V. A majority of the suspension is about the same, but about the same =/= the same. You'd have a better chance, financially, of buying a V and importing it, vs the headache that would be a total conversion.
    [2006 CTS-V]
  8. #8
    sandalet's Avatar
    Nov 2011
    39
    620
  9. Remove Advertisements
