Replacing the inner tie rod ends
Results 1 to 10 of 10
2004-2007 Cadillac CTS-V General Discussion Discussion, Replacing the inner tie rod ends in Cadillac CTS-V Series Forum - 2004 - 2007; I think I've narrowed my noise down to the inner tie rod, which is a shame because it looks like ...
    mstrjon32 is offline Cadillac Owners Enthusiast
    Automobile(s): NONE
    Oct 2010
    Mainz, Germany
    788
    I think I've narrowed my noise down to the inner tie rod, which is a shame because it looks like it's going to be an unpleasant job. Has anyone done the inner before, and if so do you have any tips for me? I found some instructions but they're pretty second-rate.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,181
    Re: Replacing the inner tie rod ends
    See attached.
  3. #3
    Automobile(s): NONE
    Oct 2010
    Mainz, Germany
    788
    darkman: Thanks man. I'm hoping someone will chime in to let me know if this is possible to change without disconnecting the intermediate shaft and dealing with all that other nonsense. I feel like I should be able to do this without taking the entire system apart...
  4. #4
    Automobile(s): NONE
    Oct 2010
    Mainz, Germany
    788
    I've been agonizing over if I should replace the inner tie rods or if I should just buy a whole new rack. A new rack is only $200 more than buying both tie rods, and is probably going to be just as much of a PITA to replace. Does any one have any opinion on whether or not this is a good idea?
    Also, the service manual says that I need some kind of a tool to lock the steering wheel center. Is it not adequate to just use it's internal locking mechanism to hold it when I disconnect the intermediate steering shaft?
    This job looks terrible, BTW.
  5. #5
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
  6. #6
    Automobile(s): NONE
    Oct 2010
    Mainz, Germany
    788
    Thanks darkman. I saw that second post but hadn't seen the first. At this point I think I'm going to go ahead and leave the rack alone and try and to just change the inner tie rods, though I have a suspicion that I'm going to come to regret that decision. I've been holed up sick all week but I took the car out for a drive earlier and the steering feels perfectly tight and fine, it's just this damn creaking noise that both sounds ghetto and has me concerned about something breaking.
    I'm pretty annoyed too because I wanted to take the car to the track this Saturday and I still don't have this damn problem fixed.
  7. #7
    rizico is offline Cadillac Owners Member
    Nov 2012
    34
    8
    Mstrjon32, did you ever do this job? I'm about to undertake the inner tie rod change on the passenger side of my wife's 07 CTS (base).
  8. #8
    eagle-co94's Avatar
    eagle-co94 is offline Cadillac Owners Fanatic
    Automobile(s): '09 V, '10 SRT8 Chlnger, '96 Impala SS, '85 Mini, '11 9C3
    Jul 2013
    Hollywood, FL
    151
    I'm in the middle of this right now and my inner tie rod came with thread locker. I presume I'm supposed to put it on the threads where it attaches to the rack? Once it's done I'm not pulling it apart again (unless someone hits my car again).
  9. #9
    xbladr is offline Cadillac Owners Fanatic
    Dec 2008
    377
    Eagle I am about to do the same thing. Do you or Darkman have the write up on this? I am only doing my front right and i already have the outer tie rod off and disconnected
  10. #10
    eagle-co94's Avatar
    Jul 2013
    Hollywood, FL
    151
    PM me your phone number and I'll call you. I think I found a write up for an SRX here on the forum through a search and it's essentially the same thing. The only issue I had was that my inner tie rod didn't come with new clamps.
  11. Remove Advertisements
