CTS-V Center Speaker in Dash Replacement
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Like Tree1Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, CTS-V Center Speaker in Dash Replacement in Cadillac CTS-V Series Forum - 2004 - 2007; Hey everyone...please forgive me if this has been answered, but I've searched and can't find exactly what I'm looking for.... ...
    PriceIsRight is offline Cadillac Owners Member
    Automobile(s): 2006 CTS-V
    Sep 2010
    14
    My '06 V has blown the center speaker in the dash. I gather that I can remove that front panel of the dash to get to it, but would like further instructions on how to pull it out (the dash panel and the speaker). I checked the "2004-V Front Dash Vent cracked" thread but couldn't find the attachment that may have the instructions. Anyone able to help?
    Thanks!!
  2. #2
    GDPossehl is offline Cadillac Owners Enthusiast
    Automobile(s): '04 CTS-V
    Feb 2011
    Decatur, GA
    507
    Re: CTS-V Center Speaker in Dash Replacement
    A flat bladed tool is all you need to remove the dash piece, the speaker however, is bose specific and I would leave it out if possible.
  3. #3
    Sep 2010
    14
    Ok, great...thanks for the help. Will probably just disconnect the speaker then...I've caught on that this whole audio system is proprietary stuff.
    Thanks for the response.
  4. #4
    Sep 2010
    14
  5. #5
    Feb 2011
    Decatur, GA
    507
    Also, be very careful with the dash piece. They become very brittle with the sun.
  6. #6
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,181
    See attached.
  7. #7
    Sep 2010
    14
    Darkman, thank you for the attachments, that's exactly what I'm looking for. Already found the Bose replacement part.
    Appreciate everyone's help.
  8. #8
    Sep 2010
    14
    I was able to find the direct replacement speaker and finally had some time to install it. Thanks for everyone's help. Only took me about 15 minutes to do. If anyone needs it, the replacement part # is 25684670. I was able to find it on Amazon for only $44, other places had it in the $80 range.
    http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
  9. #9
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    If I wanted to replace that speaker with something better, do you have any information regarding its size and impedance?
  10. #10
    Sep 2010
    14
    I'm sorry, I don't. I'm not an expert in this area... I believe the size is a 3 1/2". But maybe with that part number, you might be able to find out more information on it. Based on what I read on some other posts, you do need to be careful as apparently this system is fairly particular about what speakers you hook up to it.
  11. #11
    vcaddy06's Avatar
    vcaddy06 is offline Cadillac Owners Fanatic
    Automobile(s): '06 Black Raven CTS-V
    Sep 2009
    Palm Beach County, FL
    168
    Where is the instructions to remove dash piece? I have same problem.
  12. #12
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Quote Originally Posted by vcaddy06 View Post
    http://www.cadillacforums.com/forums...ml#post3303369
  13. #13
    sssnake's Avatar
    sssnake is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Dec 2008
    Huntsville
    48
    291
    Quote Originally Posted by FuzzyLogic View Post
    Fuzzy
    There are two aluminum dash braces on either side of the speaker that really prevent you from going larger. If I remember correctly depth is pretty limited as well. I thought it was smaller than 3.5" but could be mistaken. If you want to upgrade I would consider a flat planar driver. However to get the low freq response up you will likely have to go pretty large. With the width of the panel this will require you to orient the large side parallel to the front seats which will narrow hi freq dispersion.
  14. #14
    hevenz is offline Cadillac Owners Member
    Jan 2013
    33
    95
    I have a question... I'm a 3.6 guy... Will this work for me as well? My only other problem I'd i broke the speaker grill as well... I'm guessing i wont be able to find s new grille?
  15. #15
    jmil1974 is offline Cadillac Owners Member
    Automobile(s): 05 CTS-V
    Dec 2015
    Katy, TX
    54
    This attachment has disappeared, darkman. Would you mind reposting?
  16. Remove Advertisements
