Results 1 to 9 of 9
Thread: How to diagnose a bad wheel bearing?
    fre1102 is offline Cadillac Owners Fanatic
    Automobile(s): None yet
    May 2012
    37
    303
    I've got a groaning from the right rear on right hand turns. It used to be just right hand turns, and went away when straight. Now it's started when going straight, too, and only goes away when turning left.
    I've been under the car and the CV boots look good. I can't replicate the noise enough on stands to locate the source when under the car. Is there any other way to diagnose this short of disassembling the hubs?
    Thanks in advance.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    Re: How to diagnose a bad wheel bearing?
    See attached.
  3. #3
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,463
    Jack that corner of the car up, grab the tire and 12 and 6 o'clock, and try to wobble the wheel/tire back and forth. If there's any movement at all, the wheel bearing is bad.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  4. #4
    May 2012
    37
    303
    Quote Originally Posted by AAIIIC View Post
    I did that--no movement at all 'in and out'--just some rotational play, like there's play in the diff.
  5. #5
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,831
    Oh, there's play in the diff, all right. EVERYBODY's got play in their diff.
    Except maybe lollygagger8.
  6. #6
    yooper's Avatar
    yooper is offline Cadillac Owners Enthusiast
    Automobile(s): Escalade ESV and Caddy powered Chevy
    Aug 2009
    Michigan
    576
    Quote Originally Posted by fre1102 View Post
    Thanks in advance.
    I like to use an infra red temp gun and compare temps side to side once the drivetrain is warmed up. Check your rear axle nuts for a loose axle nut causing vibration. Rear axle nuts should not be reused. Always replace with new if you can thread on by hand!
    Light weight after market CV boots have been known to expand under continuous high speed operation and will throw out the grease which should be quite visible and could cause a vibration.
  7. #7
    greg12m3 is offline Cadillac Owners Member
    Automobile(s): ls6 cts v
    Aug 2011
    Washington DC
    25
    There doesnt have to be movement in the bearing for it to be bad in my experience. I just replaced my fronts and they had no play. Only noise when traveling above 20mph and turning(left made it louder, right made it quiter). I replaced both fronts with timkens for 300$ and the noise disappeared.
  8. #8
    jcb250r is offline Cadillac Owners Member
    Automobile(s): 2004 cadillac cts 3.6
    Oct 2012
    41
    23
    I have a noise also in my right rear wheel. I have tried diagnoise the 12:00 and 6:00 wheel shake on all of my wheels no play found, but it does make a noise wap wap wap noise intermittently. Also is popping code C0282 IDK
  9. #9
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    Quote Originally Posted by jcb250r View Post
    See attached.
    Other possibilities:
    1. We have had some reports of popping noises related to one or both of the rear wheels caused by under lubrication (from the factory) of the axle splines such that the spines become "welded" to the hub. This condition apparently creates excessive rigidity and noise. The remedy is to disassemble and lubricate.
    2. The limited slip differential can become noisy if the fluid deteriorates. This usually cause "chatter" that can be heard by doing slow turns with the driver's window down. The remedy is to change fluid and/or add some more limited-slip additive.
    3. The constant velocity joints on the rear axle can become noisy if lubrication is not maintained. This is usually caused by a torn rubber boot that allows the grease to come out. The remedy is to re-lubricate and/or replace the boot.
  • You may not post replies
