Bought an '04 V... happy but minor problems
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
2004-2007 Cadillac CTS-V General Discussion Discussion, Bought an '04 V... happy but minor problems in Cadillac CTS-V Series Forum - 2004 - 2007; Howdy fellas, Just purchased an '04 V and I'm very happy, but there apperas to be a few minor issues. ...
    rmbanas is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Jul 2012
    12
    Howdy fellas,
    Just purchased an '04 V and I'm very happy, but there apperas to be a few minor issues. I've been searching these forums and found answers to some, like the oil temp light TSB... but some others I'm curious about.
    #1: Out of nowhere the in dash display started to tell me that the anti-theft system needs to be serviced--the indash light for it won't go off. I have no idea even where to begin with this?
    #2: The dimmer switch for the dash lights worked fine, until last night. Now it doesn't work at all, nor does it turn on the interior lights... how can I get that thing apart to fix it?
    #3: I have a plugged condensate drain tube and my passenger side carpet is soaked.
    #4: My windows no longer will roll down...
    #5: The speedometer jumps around and I believe it's causing the traction control to activate... I assume the sensor needs to be replaced? Is it in the rear end or tranny?
    .... at least it runs and drives.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,162
    Re: Bought an '04 V... happy but minor problems
    Quote Originally Posted by rmbanas View Post
    Howdy fellas,
    For item#3 see the attached.
    Item #5 could be the vehicle speed sensor (VSS) which is fastened to the transmission.
    The other items could have individual causes but because they are occurring together they may be interrelated. Specifically, many of the systems in this car depend on low voltage references from the various circuits. These low voltage references, in turn depend on a strong battery and good grounding. The simultaneous occurence of multiple electrical symptoms is often caused by a weak battery or a grounds that no longer conduct well. I would start by checking the battery (for a weak cell) and its connections. I would also pull the ground under the hood strut stick and clean it some sandpaper or other abrasive.
  3. #3
    Jul 2012
    12
    Thank you for the reply. I downloaded the attachments and will take a look tomorrow to see what I can figure out.
    I blew out the rubber drain hose with some compressed air today and the water leak went away so that's fixed.
    The dimmer switch and windows are still puzzling... the lights in the upper console work fine, it's just that the dimmer switch won't activate them (I have to push the buttons) and it also doesn't dim the instrument cluster lights. Just funny that both of these items worked fine until today... I looked at the fuses and couldn't find anything, these power items seem to be relayed. I'll have to pick up a few extra relays to check and see if those are what's causing it, otherwise I'd expect it's the dimmer switch itself--which I am assuming is a pain to swap out, seeing as I can't figure out how to remove that upper console thingamabob by the rearview mirror.
    I will also check the grounding system and battery and clean it up with some sandpaper and dielectric grease.
  4. #4
    Scott2012's Avatar
    Scott2012 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 AWD CTS
    Jul 2012
    Minnesota
    40
    261
    If all the windows are not rolling down, that might be a power issue... Have you checked the fuse box? Also, you should grab a volt meter and enure you have 12v at you switches, the pull h door panel the check power at the motors. That would be step 2, in my opinion.
    There cold be something else... As noted above, if you have grounding issues you could have voltage drops too
  5. #5
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,162
    See attached.
  6. #6
    Jul 2012
    12
    So I brought the car into the dealership today and they scanned it... they claim that the problems are all related;
    The diagnosis indicated that there are 5 modules (I didn't get the report) that are not communicating with each other -- I assume body control, door, anti-theft, vehicle speed/dash, etc.
    so, I'm going to try and get the dealer to cover the repairs seeing as selling a vehicle with a broken speedo is odometer fraud, right?
    If that doesn't work though, any clues as to where to begin?
  7. #7
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    I hope that you can figure out what's going on with the V. If I were you, I'd check the date on the battery as a starting point.
  8. #8
    Mn800r's Avatar
    Mn800r is offline Cadillac Owners Fanatic
    Automobile(s): 11 V Coupe, 05 V Mod'd, 91 Fatboy,98 Ultra classic, 07 Tahoe
    Jul 2012
    Scandia MN
    50
    383
    Congrats on your purchase,,I too am a recent V owner,it has me running around town and net to figure WTF is all the issues!. If it wasn't for this mid-life crisis and happy flapper it has I would sell the SOB!.
    Best of luck and hope your wallet is very fat! I feel better now...thanks..
  9. #9
    Cadillac Cust Svc's Avatar
    Cadillac Cust Svc is online now Cadillac Customer Service
    Mar 2010
    Detroit, USA
    12,674
    ...so, I'm going to try and get the dealer to cover the repairs seeing as selling a vehicle with a broken speedo is odometer fraud, right?
    Rmbanas, please feel free to contact me to explore your next steps if you do indeed have concerns after consulting with your dealership. My email is Katie_Lucille@gmexpert.com!
    Best,
    Katie
  10. #10
    Jul 2012
    12
    Ugh... ok so I tried to disconnect the battery but the terminal bolt stripped, someone really tightened the hell out of it on the positive cable. So I disconnected the cable from the main fuse box, shorted it as told, and it reset the computer. My problems still exist, plus new ones! My tire gauge doesn't register the tire pressures and I no longer have my XM bands on my radio (which previously worked just fine)... is there any way to fix this stuff without having to take it to the dealer?
    I'm also starting to wonder if my power windows problem is related to some literature I found on the net about some connectors getting corroded under the rear carpet... remember I had that water leak from the air conditioner and there was standing water in the floor.
  11. #11
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,162
    What do you mean by "shorted it"? I am not familiar with that procedure.
  12. #12
    Jul 2012
    12
    Connected the positive terminal in the fuse box (i.e. where the battery cable goes) to the negative end of the battery, to discharge any capacitive load in the system.
    I just took another look in the car... re-checked all fuses, swapped around relays and breakers, still no power to the drivers door windows although the mirrors work fine, etc. and my radio still does not display any XM bands.
    This is sufficiently irritating me now... I'm the kind of person that gets OCD over problems until they are fully solved to my satisfaction.
  13. #13
    Jul 2012
    12
    Oh one other neat thing I forgot to mention... I went through the DIC and asked it to display the battery voltage, it just reads --.-- what's up with that?
  14. #14
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,162
    Attached is view of the body harness in the passenger compartment. The wiring beneath the carpet includes connectors of the air bags - you should therefore disconnect the battery before working on/troubleshooting the body harness.
    This is the sort of task I usually take to a dealer, or at least a shop with GM TechII scanner.
  15. #15
    Jul 2012
    12
    FYI as a quick follow up... the dealer determined the body control module to be faulty, replaced it and all is well--everything works as it should now.
    Windows work... XM works, etc etc etc.
  16. Remove Advertisements
