Results 1 to 7 of 7
Thread: Door electronics problem
    madramper is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    May 2012
    Alloway, NJ
    37
    34
    I am having a problem with my car. It has happened a few times now and seems to be pretty random. The window and door lock switch work fine and work the other doors, but the drivers door lock and window don't work. Also, when you open the door to get out, the door won't unlock automatically and the radio stays on. Then it seems like the next time you start it, its back to normal and everything works. Is this a common problem? Any ideas before I tear the door apart?
  2. #2
    CTSV_510's Avatar
    CTSV_510 is offline Cadillac Owners Connoisseur
    Automobile(s): '06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
    Jan 2008
    West Chester, PA
    34
    4,455
    Quote Originally Posted by madramper
    I would check the wires where they go into the door near the hinge. Maybe something is getting pinched.
  3. #3
    jmargo is offline Cadillac Owners Fanatic
    Automobile(s): 04 V
    Dec 2011
    Nor Cal
    169
    Re: Door electronics problem
    Mine does that randomly when its wet outside
  4. #4
    etcts-v's Avatar
    etcts-v is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V, 423 RWHP / 380 RWTQ
    Nov 2010
    Seattle, Washington,
    35
    578
    Sounds like the harness may be loose or a bad door pin switch?
  5. #5
    Mar 2010
    Detroit, USA
    12,711
    Sorry to hear that, Madramper! I'd recommend visiting a dealer so a technician can run some diagnostic tests to see what's causing your driver's side concerns. If you prefer the Do-It-Yourself approach, though, I can appreciate that and hope you'll keep us in the loop!
    Katie
    Cadillac Customer Service
  6. #6
    May 2012
    Alloway, NJ
    37
    34
    Sorry for the delay, I guess I was not getting notification emails.
    Anyway, I replaced the driver's door module and all is well now. Thanks!
  7. #7
    Cadispeedster's Avatar
    Cadispeedster is offline Cadillac Owners Fanatic
    Automobile(s): 06 CTS-V, Dec 20, 2005
    Jan 2013
    174
    Thread back alive...
    Having similar issue. Personalization system seems to be stuck off and can't turn it back on. So the personalization options do not work nor does any of the driver side control buttons, such as the driver side lock an unlock / windows up and down, and driver 1&2 buttons... Took to cadillac for diagnosis and they said the radio navigation unit needs to be replaced. It all communicates together. $1600+ for new unit plus install.
    Now looking for options to replace the radio with an aftermarket while getting the driver side window buttons to work again. Really unhappy about this. I know there's a way to get a normal cts radio but not sure if it'll fix the issue with the driver side buttons not working.
  • You may not post replies
