Bank 1 oxygen sensor?
Results 1 to 13 of 13
2004-2007 Cadillac CTS-V General Discussion Discussion, Bank 1 oxygen sensor? in Cadillac CTS-V Series Forum - 2004 - 2007; My check engine light is on--the code says it's the "Bank 1 oxygen sensor"--there appear to be three oxygen sensors ...
    fre1102 is offline Cadillac Owners Fanatic
    Automobile(s): None yet
    May 2012
    36
    296
    My check engine light is on--the code says it's the "Bank 1 oxygen sensor"--there appear to be three oxygen sensors on the car, can anyone tell me which one is the 'bank one' sensor, where it is, and how difficult it is to change?
    Thanks.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    Re: Bank 1 oxygen sensor?
    There are four oxygen sensors. Bank 1 is the driver's side and Bank 2 is the passenger's side. Each Bank has a Sensor 1 which screws into a bung on the exhaust pipe just upstream of the catalytic converter; and a Sensor 2 which screws into a bung on the exhaust pipe just downstream of the catalytic converter.
    They are not difficult to change if you a wrench that fits. The sensors are available at parts stores.
  3. #3
    May 2012
    36
    296
    Quote Originally Posted by darkman View Post
    Thanks. So if it's just saying 'Bank 1' do I swap out both of them on the driver's side?
    Thanks again.
  4. #4
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by fre1102 View Post
    Thanks again.
    The specific code will tell which sensor has the problem.
    DTC P0135 for HO2S bank 1 sensor 1
    DTC P0141 for HO2S bank 1 sensor 2
    DTC P0155 for HO2S bank 2 sensor 1
    DTC P0161 for HO2S bank 2 sensor 2
    Additionally, there can be other issues that cause the code to set. Do you know the specific code?
  5. #5
    May 2012
    36
    296
    Huh. The reader just said "Bank 1". I guess I need to get it read by a different reader?
  6. #6
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    A code scanner cost about the same as one oxygen sensor. On the other hand, if you've got more time and energy than money you could swap the Bank 2 sensors over to Bank 1 one at a time (clearing the codes in between by disconnecting the battery for a few minutes) and determine which sensor it is by elimination. Of course, this all presupposes that the issue is not a loose wire, faulty cat, or the like. Finally, before anything else you should check the PREO2 and POSTO2 fuses in the underhood fuse box as discussed in the PDF.
  7. #7
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,361
    i just got a code p0161 today. On-star told me. Does that mean all i need to do is change DTC P0161 for HO2S bank 2 sensor 2 out? Also any diagram with
    location would be helpful. I just like to see what it looks like before going under the car is all.
    Thanks
  8. #8
    odla's Avatar
    Nov 2006
    miami ,Fl
    2,361
    repost
  9. #9
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Quote Originally Posted by odla View Post
    i just got a code p0161 today. Does that mean all i need to do is change DTC P0161 for HO2S bank 2 sensor 2 out?
    Hardly - it means you have blown a fuse, have a failed cat, have a loose wire, have a bad ground, have a bad sensor, or see attached.
  10. #10
    odla's Avatar
    Nov 2006
    miami ,Fl
    2,361
    OK thanks.
  11. #11
    PISNUOFF Guest
    True. But most likely you have a bad O2 sensor. It's the passenger side one farthest from the motor.
  12. #12
    odla's Avatar
    Nov 2006
    miami ,Fl
    2,361
    i hope so. i wiggled any wires i could get to under the car on both sides. i checked the fuses. should i try and find an ac delco part?
  13. #13
    odla's Avatar
    Nov 2006
    miami ,Fl
    2,361
    Update.
    Wanted to say thanks guys. Replaced the sensor and it is good now.
  14. Remove Advertisements
