Pa15-vette help
Results 1 to 11 of 11
2004-2007 Cadillac CTS-V General Discussion Discussion, Pa15-vette help in Cadillac CTS-V Series Forum - 2004 - 2007; Hooked up the pa15 and now the nav won't switch to xm... Fm1, fm2, and am only. Anyone else run ...
    Bigtuna819 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Oct 2011
    NJ/NYC
    31
    68
    Pa15-vette help
    Hooked up the pa15 and now the nav won't switch to xm... Fm1, fm2, and am only. Anyone else run into this?
    It charges the phone, but can't get the radio to switch in the xm input... Unhook everything, and hook the regular wire harness back up and the xm works fine...
  2. #2
    perfect's Avatar
    perfect is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac CTS-V Platinum
    May 2008
    Kansas City
    33
    1,182
    Re: Pa15-vette help
    I had the same problem when I first installed and it turned out that I hadn't really plugged the connector into the XM module very well. I hope that your car is still taken apart so you can test and confirm.
    Also make sure the dip switches are set up correctly on the PA15 unit - otherwise you'll likely get no connection at all.
    Also - USA Spec tech support is spot on. If all else fails - give them a call.
  3. #3
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Re: Pa15-vette help
    That problem is indicative of one of two problems (the unspoken third is that the PA15 head unit or your XM unit is dead):
    1. You didn't connect everything correctly and securely (agree with perfect).
    2. Occasionally, the connection between all of these type of units (not just the USA Spec ones) will blink out if you disconnect your iPod / iPhone a lot while the car is running. The fix is to de-energize the electrical system (disconnect the battery for a minute). It's very rare--I've only had to do it once over the past two years.
  4. #4
    jwilson2598's Avatar
    jwilson2598 is offline Cadillac Owners Member
    Jun 2011
    Front Royal, VA
    40
    69
    Mine did it the very first ride I took after installing it. I turned the car off for a minute, then restarted it and it was working again. Hasn't done it since.
  5. #5
    Oct 2011
    NJ/NYC
    31
    68
    Re: Pa15-vette help
    the pa15 head unit was dead, just swapped in a new one and everythings good. beware of the ebay and amazon sellers... luckily mine sent me a replacement...
  6. #6
    Senor Aguas's Avatar
    Senor Aguas is offline Cadillac Owners Member
    May 2011
    Fayetteville, AR
    37
    39
    Re: Pa15-vette help
    mine did it twice in the beginning and hasn't done it since. not sure why but it works now.
  7. #7
    JPGIII is offline Cadillac Owners Member
    Automobile(s): 05 CTS-V
    Aug 2010
    San Diego, CA
    34
    23
    Just installed my PA-15 and seem to be having the same issues of it turning off and then restarting by itself. Not sure what is going on with it. I have dip 2 on and the other 3 off. Is this the way you all have them?
  8. #8
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Pa15-vette help
    My gf's has done that twice in the 2 yrs since I put it in her SRX for her. Disconnect the battery for a few minutes and it'll come back. Assuming you have it connected correctly.
  9. #9
    acaringnihilist is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V
    Nov 2011
    Michigan
    40
    Re: Pa15-vette help
    Quote Originally Posted by jwilson2598 View Post
    Same here.
  10. #10
    caseyschier's Avatar
    caseyschier is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Oct 2011
    Montgomery, TX
    42
    Re: Pa15-vette help
    I'm on my third pa15 box. I actually bought it from NeoPro, but it is the same box. The first two were no good and I had a lot of problems with them. This last one finally decided to work, but I do notice that the advanced mode doesn't work consistently (through the 30 pin connector port). I don't know if that's a problem with the DIP switches or not, but I mainly only use the aux cord anyways, so I don't care enough to mess with it anymore.
  11. #11
    Mar 2011
    2,045
    Re: Pa15-vette help
    Quote Originally Posted by caseyschier View Post
    Sounds like installer error.
  12. Remove Advertisements
