Results 1 to 6 of 6
Thread: Bad Drive Axle???
    Steve 0-V-Man is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac CTS-V
    Sep 2011
    Bad Drive Axle???
    So I took my 2004 CTS-V that I bought 3 weeks ago into the shop today for an oil change... much to my disliking they told me that the right drive axle and seal needed to be
    replaced due to a leak (it doesn't seem to be a big leak since I have driven the car 2,500 miles since I bought it and they still said it had plenty of fluid after I asked them to check the level for me). The reason why I am writing this is because I would like a second opinion from you guys, do I really need a new drive axle or do I just need a seal???
    Thanks!
  2. #2
    Sep 2011
    Re: Bad Drive Axle???
    Also let me add the car still drives fine and doesn't make any abnormal noises... thought that might be some relevant information to add lol
  3. #3
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    I think you need: (a) a new shop; and (b) a seal - in that order.
    (With that said, the labor for changing the seal is almost the same as the labor for replacing the axle because of the overlap in the two processes. So, if you do not have aftermarket axles already you might investigate one of those single-axle wheel hop solutions from GForce.)
  4. #4
    PISNUOFF Guest
    I agree. Also, the aftermarket ones are cheaper than a new one from a dealer. The seal is less than $20 and is pretty easy to change. The first time you do it, it may take you about 1.5 to 2 hours. I have it down to 43 minutes. Lol
  5. #5
    rjoffe is offline Cadillac Owners Connoisseur
    Jul 2005
    1,913
    Are you sure it's leaking from the seal? Some V1's leaked from the drain at the top of the diff, and this may have leaked down the side right where the seal is at. You may want to clean it up real well, and take a look again to see where the fluid is located.
  6. #6
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    If you are taking the axle out, you might as well replace it with something better.
    http://www.cadillacforums.com/cadill...eelhop-21.html
  • You may not post replies
