weird noise...help please
Results 1 to 8 of 8
2004-2007 Cadillac CTS-V General Discussion Discussion, weird noise...help please in Cadillac CTS-V Series Forum - 2004 - 2007; I have looked and have not found anyone with the same problem as I am having with my car(05 CTS-V, ...
    DrSzabo's Avatar
    DrSzabo is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V - Light Platinum
    Feb 2010
    Dallas, Tx
    56
    I have looked and have not found anyone with the same problem as I am having with my car(05 CTS-V, only mods are custom intake and Magnaflow exhaust). Regardless of what gear I am in, if I down shift and accelerate hard I get a clunky/grinding sound for a couple seconds. For example, at about 50mph I downshift into 3rd, and when I accelerate, that grinding/clunking noise happens for a couple seconds and then goes away as I continue to accelerate. It seems to do this when I am at higher RPMs. My buddy drove next to me and said it sounds like it is coming from the front of the car. When I drive easy I don't hear the sound, and with my windows up I never hear it. Apparently it is very loud and noticeable from outside the car. I am thinking this is motor mounts that have gone out, but I am not sure as I have never needed to replace a motor mount on a car before. I was hoping to get some info before bringing it to the shop and getting raped on the charges, unfortunately I do not have the tools or know how to check on motor mounts. Thanks for any help!!!
  2. #2
    jmpumford's Avatar
    jmpumford is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Maggied CTS-V
    Oct 2010
    Los Angeles, CA
    34
    253
    Re: weird noise...help please
    Hopefully someone can help you diagnose the noise better than I can. It it helps, I knew my MMs were bad because when I would turn it off, it felt like a cummins diesel being shut down. The install really wasn't bad and not too many tools are needed. I changed my worn out ones to CS steel ones using the following videos:
    http://www.youtube.com/watch?v=WzOpfqZM1cE
    http://www.youtube.com/watch?v=2GJ7N8FU_r4
  3. #3
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    I'm thinking MMs, too.
    Do you get that roughness sound on shutdown?
  4. #4
    DrSzabo's Avatar
    Feb 2010
    Dallas, Tx
    56
    It doesn't seem to have any unusual sounds ever, unless I drop it into a lower gear and punch it.
  5. #5
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Check underneath the car for leaking out of the MM's. The fluid is originally greenish but exposed to air and drying makes it look brownish. My drivers side leaked onto the oil pan when it broke and could've been mistaken for an oil leak.
  6. #6
    MotorMounts's Avatar
    MotorMounts is offline Cadillac Owners Fanatic
    Automobile(s): 04 Black CTS-V
    May 2009
    Salem Oregon
    50
    400
    Who's in Dallas that has our mounts, that did the install thems selves that would like to make a few extra bucks installing DrSzabo's mounts, atleast get the car on a lift for an inspection to see if infact they are bad. This is kind of a twist....giving the doctor the bad news, usually it's the other way around. Sorry Doc, it really does sound like the mounts are bad. If you do need to go to a shop to have them replaced, don't pay for more than 3 hours of shop time. Any more than that....keep shopping.
    Our phone number is 503-316-1811 We're here M-F, 8-5 Pacific Time.
    http://www.creative-steel.com
    maxx@creative-steel.com
  7. #7
    67electro is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Jun 2009
    35
    87
    if it only happens when under load and at higher rpms, are you sure its not just engine detonation? (Pinging)?
    sounds like gravel in the engine.
  8. #8
    DrSzabo's Avatar
    Feb 2010
    Dallas, Tx
    56
    thanks for the help...I will look and see if I see the fluid leaking tonight. I dont think its detonation...sounds like metal on metal, but it is tough to describe.
  9. Remove Advertisements
