Driver HID turns on and off when cornering/braking hard
Results 1 to 3 of 3
2004-2007 Cadillac CTS-V General Discussion Discussion, Driver HID turns on and off when cornering/braking hard in Cadillac CTS-V Series Forum - 2004 - 2007; I have a strange issue, the HIDs in my car work fine 95% of the time. With spirited driving, however, ...
    killernoodle is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V --- the RED one :)
    May 2010
    31
    281
    I have a strange issue, the HIDs in my car work fine 95% of the time. With spirited driving, however, the driver side HID will turn off and then come back on about 10 seconds later, then goes off 10 seconds later, then back on, then off, etc until it finally gives up and stops working until the lights are shut off for a little while. Before I go ripping apart my wiring and swapping bulbs around, do any of you guys have any idea what might be going on?
  2. #2
    branland's Avatar
    branland is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V SC
    Jun 2008
    San Diego
    54
    400
    Re: Driver HID turns on and off when cornering/braking hard
    I had that happen to me. I replaced both bulbs and it went a way temporarily, then it started happening again. I ended up replacing both ballast. Every now and then I still have an issue if the lights come on automatically when it gets dark.
  3. #3
    hkd
    hkd is offline Cadillac Owners Member
    Apr 2005
    87
    Had this issue also. Dealership replaced my entire head lamp assembly and its been good since. If you search, you may find some threads about this issue. Some claim re-routing the headlamp wire harness away from the spark plug wires will correct the issue.
