Low speed Clutch operation....stuck to floor
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V General Discussion Discussion, Low speed Clutch operation....stuck to floor in Cadillac CTS-V Series Forum - 2004 - 2007; ...
    ryand is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V Black
    Jun 2009
    34
    64
    Hi all,
    Want to talk over a problem that developed with my 05 v….I searched but am not finding much on low speed issues. Today for the first time in 95K miles my clutch went to the floor and never returned…had to pull it up with my foot. All low speeds, down shifting into a parking lot. Pumped the clutch and got it back and it did it again. It feels very soft now. Checked the fluid and its brown. I found a lot of info on high RPM issues but not much on low RPM. I baby this car and rarely do I hammer it. It must also be noted that it is record heat today….101 don’t know if that might have anything to do with it.
    Any suggestions???
  2. #2
    Crash-Override is offline Cadillac Owners Member
    Automobile(s): 2005 Stealth Gray CTS-V
    Sep 2010
    South Nashville
    37
    89
    Re: Low speed Clutch operation....stuck to floor
    I would do a fluid flush (not just replace the top part) and give it a test, if not that then you may be looking at master/slave issues. I am sure others will chime in with some ideas.
  3. #3
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,162
    I agree that the first step is to flush and bleed the hydraulic system. If that does not work, and that is the original clutch it may be any one of a number of things such as failure of the master cylinder, slave or the pressure plate.
  4. #4
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,815
    As Crash and darkman have suggested, I'd bet that a clutch fluid flush and fluid replacement will make all the difference.
    Being the cheapest possible solution makes it all the better, too.
