How to install Zo6 Fuel Rail Covers?
Results 1 to 13 of 13
2004-2007 Cadillac CTS-V General Discussion Discussion, How to install Zo6 Fuel Rail Covers? in Cadillac CTS-V Series Forum - 2004 - 2007; Does anyone know what mods need to be done in order to install Zo6 Fuel Rail Covers? Tried doing it ...
    KING03 is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS-V
    Jun 2011
    63
    Does anyone know what mods need to be done in order to install Zo6 Fuel Rail Covers? Tried doing it last night and thought they snapped right on
  2. #2
    ahahnu's Avatar
    ahahnu is offline Cadillac Owners Connoisseur
    Automobile(s): '05 LS6 V Stealth Grey; '14 Z71 SLT Sierra 1500 Stealth Grey
    Dec 2004
    Tailgating at Giants Stadium
    37
    2,821
    Re: How to install Zo6 Fuel Rail Covers?
    When I installed my GTO FRC I had to cut off and reattach the mounting points to match our fuel rails. Took a bunch of trial and error but looks great.
  3. #3
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    I installed Z06 covers. I am assuming you mean the FRC from the C5Z? Those will indeed snap right on, however, you have to trim a couple areas for them to fit the V-specific LS6. And this assumes you have an 04-05 V. If you have an 06 or 07, then you need the base corvette LS2 covers, or the LS7 covers. Those will also require trimming, but they should snap on otherwise.
  4. #4
    Jun 2011
    63
    i bought red ones off the forums, i have an 05 cts-v
  5. #5
    Jun 2011
    63
    Which areas do i have to trim?
  6. #6
    Dec 2006
    42
    37,302
    I don't remember. When you lay them down on top of the fuel rails, you will see where the interference is. Just trim as needed to get them to fully snap into place. Here is a picture of mine:
  7. #7
    jcollege is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Raven CTS-V
    Sep 2010
    Northern Virginia
    36
    209
    Here is what I did to install mine:
    1. Trim a little
    2. Test fit
    Repeat steps 1 & 2 until there is clearance, then they will snap right on.
  8. #8
    Dec 2006
    42
    37,302
    that's the way to do it.
  9. #9
    Jun 2011
    63
    Thanks for the info, will be doing it this weekend
  10. #10
    50 4Ever's Avatar
    50 4Ever is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V (Thunder Grey)
    Dec 2005
    Sacramento Kalifornia
    66
    1,665
    I have an 07 and bought the LS2 fuel rail covers. From what I remember the left one (passenger side) snapped on without trimming. The right one needed to be trimmed to clear the power steering pump, and on the right one the corvette has a fuel line that goes thru the cover where it doesn't on the V (the fuel line is under the cover). So there is a hole in the cover. On the underside of the cover where the hole is there is a piece of plastic that needs to come off to clear the fuel line on the V. Once those are done the thing just clips on.
    As I remember the C5Z red covers need the same mods, I did those a long time ago for my '05 V.
    Good luck...
  11. #11
    Sep 2010
    Northern Virginia
    36
    209
    When I did my LS2 covers, both sides required trimming. The passanger side, definitely required a lot less than the drivers side, but still had to do some.
  12. #12
    Jun 2011
    63
    Anyone have pics of were to trim?
  13. #13
    Senor Aguas's Avatar
    Senor Aguas is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    May 2011
    Fayetteville, AR
    36
    39
    FYI, I tried 5 or 6 different tools (dremel, hot knife, etc) and a scroll saw with a high TPI blade worked best.
    You'll see where to cut. I went through about 10 iterations of marking with a sharpie and cutting it out.
    I put a picture here but it doesn't show where it needs to be cut:
    http://senoraguas.blogspot.com/2011/07/new-ride-2004-cts-v.html?m=1
  14. Remove Advertisements
