Coolant T fitting leaking
Results 1 to 3 of 3
2004-2007 Cadillac CTS-V General Discussion Discussion, Coolant T fitting leaking in Cadillac CTS-V Series Forum - 2004 - 2007; Has anyone had problems with the coolant T fitting that sits on top of the radiator? mine is leaking under ...
    mrmojo95's Avatar
    mrmojo95 is offline Cadillac Owners Fanatic
    Automobile(s): 05 Cts-v Ls7 Clutch/Fly, Cam, LEDint/ext, side exit exhaust
    Oct 2008
    Grand prairie texas
    45
    127
    Has anyone had problems with the coolant T fitting that sits on top of the radiator? mine is leaking under load. I'm about to chop it out and put in a brass piece, but I'm concerned that the OEM is so stout looking, and extremely expensive that it may have more function than i am anticipating...
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,199
    Re: Coolant T fitting leaking
    No magic here - just plumbing. You can replace the T and any of the connecting hoses as long as the replacement compoents are designed to handle high temperature and a few psi of pressure.
  3. #3
    mrmojo95's Avatar
    Oct 2008
    Grand prairie texas
    45
    127
    Right on. No issues. Simple fix. Thank you.
