Another broken rear window regulator... tips on replacing? - Page 2
Results 16 to 30 of 34
Like Tree2Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Another broken rear window regulator... tips on replacing? in Cadillac CTS-V Series Forum - 2004 - 2007; Rock Auto sells two replacements (excluding the AC Delco which includes the motor). One is a Dorman for just under ...
  1. #16
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,164
    Re: Another broken rear window regulator... tips on replacing?
    Rock Auto sells two replacements (excluding the AC Delco which includes the motor). One is a Dorman for just under $60 and the other is Cardone for roughly $130. The Cardone claims to be improved with less brittle "gears."
  2. #17
    awdtalon92 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Jul 2011
    39
    14
    This is the first thing I had to do to my V. The right rear regulator broke the first day I got it a month ago. Sounded nasty with the wire getting crunched up in tere. Turned out to be a VERY easy job. Don't get the OEM, the Dorman replacement is fine, and you should be able to find it for ~$50 online. Try Amazon.com
    The whole thing took me about 2 hours. 1 to take it out, order the part, and 1 to put it back in. Mind you, I had never been in a V prior to doing the work. The FAQ has great instructions on removing the door panels. Once it is all out, just jam a block of wood to hold up the glass, two bolts holding the regulator to the glass, and 5 bolts holding the regulator and 3 bolts attaching the motor. An Allen key works fine for removing the 3 torx bolts.
    I was pleasantly surprised at how easy the job went. Also, this being my first American car, surprised at how differently the Japanese put things together.
  3. #18
    GDPossehl is offline Cadillac Owners Enthusiast
    Automobile(s): '04 CTS-V
    Feb 2011
    Decatur, GA
    506
    So my pass side rear window decided to fall open Saturday. It only goes down about 4-5" and can be pushed up. I head the motor working, but it doesn't move. Does this sound like a broken regulator?
    I don't want to order the part before I know I need it, but I don't want to not need it when I open it up. Conundrum.
  4. #19
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,164
    It sounds like a regulator to me. For what it is worth, my local auto parts store (OReilly's) sells these albeit for a little more than online. The convenience of being able to return it locally if not needed might be worth the added cost.
  5. #20
    Jul 2011
    39
    14
    Do yourself a favor and pull open the door. Will only take 15 minutes, it's not hard at all.
  6. #21
    Irs13 is offline Cadillac Owners Member
    Jun 2013
    1
    I just had my passenger side read window break last night. Is the attachment still available?
  7. #22
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,164
    See attached.
  8. #23
    PJGross is offline Cadillac Owners Fanatic
    Apr 2008
    168
    Look at that, an old thread of mine! What you will find is a garbled mess of wire b/c one of the pulleys on the old reguator likely broke and the non-tensioned wire just goes wherever. It doesn't matter if the regulator works or not, there is no fixing it. Once one of the plastic pulleys fails, that wire is a mess. I should have taken pictures but Darkman's files show it pretty well.
    It really wasn't that hard of a job. Just make sure to plug in all the pigtails afterwords. Don't ask how I know that.
    -PJ
  9. #24
    67electro is offline Cadillac Owners Member
    Jun 2009
    35
    87
    Hey Darkman, could you re attach the PDF for the rear window regulator replacement info? I am about to replace my Right Rear. rolled up the window and heard all kind of shattering pully noises coming out. and no window moving.
    got the new one today.
  10. #25
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Ummm....where's your writeup with pics, PJ??
    rand49er and NCOGNITO like this.
  11. #26
    Jun 2009
    35
    87
    never mind, I figured it out. took me 1 hour to do.
    you have to remove the plastic lock knob at the top, then pop out the plastic oval cover behind the door grab and remove 2 screws. then remove the bezel behind the door latch handle. you can youtube this.
    then pop the door panel off working your way around starting at the bottom.
    then you have to remove the door electrical socket plate, (4 nuts) then unclip the door control module and let hang. then peel back the plastic and use a razor blade to cut the gooo stuff as you peel back the plastic. it keeps it from being stringy and you can just re stick it back later.
    the door glass is held in by two bolts, just loosen them, and use some SCOTCH tape on the outside of the glass to hold it in the all the way up position, it actually holds it self up with just the window seals, but the tape keeps it up for sure.
    unhook motor wire, then remove the old regular by removing 5 bolts.
    transfer motor to new regulator.
    pre loosen the new regular to door glass clamp bolts (2)
    install new regulator and leave all bolts loose until you get all 5 back in (pretty easy) then go ahead and tighten them.
    then remove the tape from window glass, and slide the glass down into the new regulator clamps, check the rubber to make sure its touching the glass and not metal.
    then use driver door to roll the window back up. then tighten the new regulator to glass clamp bolts.
    put door back together.
    hope this helps someone.
  12. #27
    Apr 2008
    168
    Quote Originally Posted by lollygagger8 View Post
    dang, called out on a 2 yr old thread! Whatever I do now I take pics, just in case.
    Randy wants pics of an on-car Maggie rear belt install..... I have pics, but not of that belt going on, not on my car anyway.
    I'm pulling the Maggie tonight and guess what, yep, taking pics even though nobody cares.... but someone will always ask, "where are the pics" so I gotta burn some memory on the cam.
    Wow, called out on a 2 yr old thread..... ouch.
  13. #28
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,815
    Quote Originally Posted by PJGross View Post
    I've upped my request. I wanna youtube vid.
  14. #29
    wifesv is offline Cadillac Owners Member
    Jan 2011
    41
    Darkman,
    can you attach the regulator replacement again? mine just went...
  15. #30
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,164
    See attached.
  16. Remove Advertisements
