Amp power wire on fuse block power?
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, Amp power wire on fuse block power? in Cadillac CTS-V Series Forum - 2004 - 2007; I've searched and seen that one of the mods hooked a sub amp power wire into the fuse box power ...
    LS6Steve is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Jun 2011
    San Jose, CA
    132
    I've searched and seen that one of the mods hooked a sub amp power wire into the fuse box power under the rear seat. Doesn't seem to be common practice in the threads i've read. Will I run into any trouble with this ever? With whatever other accessories that are tapped into that power wire, when beating out the sub is it too much draw on that factory power wire? I don't want to chase meltdowns later or start a fire. I only have a 350w (rms) amp on a JL 12w3 but I've always run dedicated power wires to the battery. This seems like it would save a LOT of trouble if it works. Do I put another fuse there as well?
    Thanks for any advice
  2. #2
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,787
    Re: Amp power wire on fuse block power?
    I tapped into that power line and I have no problem.
    I didn't add a fuse as the amp has one.
  3. #3
    DrSpeed's Avatar
    DrSpeed is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Jun 2009
    San Francisco, CA
    298
    Which fuse block, the left one or right one?
  4. #4
    Nov 2004
    8,787
    I tapped the power wires (2) that run between the two boxes.
  5. #5
    Jun 2011
    San Jose, CA
    132
    Quote Originally Posted by heavymetals View Post
    Exactly what I did too
  6. Remove Advertisements
