Finished first trackday, couple of issues...
Results 1 to 13 of 13
2004-2007 Cadillac CTS-V General Discussion Discussion, Finished first trackday, couple of issues... in Cadillac CTS-V Series Forum - 2004 - 2007; Posted on LS1 as well... So I just finished my first trackday at Thunderhill today. Car was everything I expected, ...
    catch2otwo is offline Cadillac Owners Fanatic
    Automobile(s): CTS_V
    Mar 2011
    SF Bay
    144
    So I just finished my first trackday at Thunderhill today. Car was everything I expected, mushy, soft, fat etc etc. But its what I expected, car is all stock, I wanted to get a "baseline" for it before I started modding.
    Temp was about 93 F at around noon.
    Issue one:
    Seems the power streering fluid resevoir blew fluid over the top of the motor. After my first session, there was oil all over the top of the intake, valve cover etc. At first thought, I suspected the resevoir was over filled but didnt see any min/max lines on it. Second session, same thing, but way less oil. Third session, same thing but again less oil.
    Where should the res be filled to? Or do I have a defective cap or something?
    Issue two.
    Had some oil seeping from the oil filter. Enough to create a couple drips to create a quarter size spot on the ground. This im just thinking its a bad gasket. Filter is a wix. I tightened it as much as I could with my hand which was only a tiny bit but it still leaked a little. Any other common areas there that may leak some oil?
    All in all I was happy tracking it today. Cant wait to go back out with a good set of pads and some new suspenders.
  2. #2
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Re: Finished first trackday, couple of issues...
    Suck out the old PS fluid with a turkey baster. Refill it with Redline.
    Sounds like a gasket on the filter.
  3. #3
    Mar 2011
    SF Bay
    144
    why change out the ps fluid? care to explain?
  4. #4
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    Zip tie a couple layers of a old t-shirt around the cap.
  5. #5
    UnsafeAtAnySpd's Avatar
    UnsafeAtAnySpd is offline Cadillac Owners Connoisseur
    Automobile(s): '04 CTS-V, '07 SRT8 Jeep, '86 Fiero
    Aug 2007
    Arlington, VA
    31
    1,647
    Quote Originally Posted by catch2otwo View Post
    I mentioned this in your other thread, but it's getting too hot. The synthetic fluid doesn't have as much issue with this. I run Amsoil in mine as I'm a dealer. While the switch seemed to help some, the spill over didn't stop until I went with the larger PS cooler.
  6. #6
    mstrjon32 is offline Cadillac Owners Enthusiast
    Automobile(s): NONE
    Oct 2010
    Mainz, Germany
    788
    Mine will blow fluid past the cap when I'm using it on the track. I did a complete flush with Amsoil, but every time I open the hood after a run, there is some fluid near the area around the reservoir.
  7. #7
    Aug 2007
    Arlington, VA
    31
    1,647
    Quote Originally Posted by mstrjon32 View Post
    Upgrade the cooler for about $40.
  8. #8
    Feb 2007
    Cheese land
    1,596
    Try a fluid change first. I had no issues with overflowing yet with Redline. If you still have a problem, then a cooler is good advice.
  9. #9
    Mar 2011
    SF Bay
    144
    Read your comments unsafe on ls1. Looks like ill get on it
  10. #10
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Normal stuff on the PS fluid.
  11. #11
    Aug 2007
    Arlington, VA
    31
    1,647
    Quote Originally Posted by crankedupforit View Post
    Lucky you. I've almost always had issues even with different fluid. Good place to start though.
    I guess I neglected to note the part number, but I picked up my cooler from Summit I believe. Here's a picture comparing it to the stock unit:
  12. #12
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,179
  13. #13
    JustinC is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Feb 2010
    38
    60
    Im running a clean flush of redline fluid. If I fill over 1/2 on the PS res then some of it gets pushed out. Same with the other V I run at the track with.
    What tires are you running? I've been in the same V running Falken 452s(meh), Re-11s, awesome and Hoosier R6s which make you think you're suddenly in a car that weighs 800lbs less! Nothing soft and mushy about em! This was with Ferodo DS2500 pads.
  14. Remove Advertisements
