Knock when trying to shift into higher gear while rpm's are high
Results 1 to 5 of 5
Like Tree1Likes
  • 2 Post By rand49er
2004-2007 Cadillac CTS-V General Discussion Discussion, Knock when trying to shift into higher gear while rpm's are high in Cadillac CTS-V Series Forum - 2004 - 2007; I just recently bought a an 04 cts v with almost 60,000 miles on it. This is my first cadillac, ...
    rumble86 is offline Cadillac Owners Member
    Automobile(s): 04 cts-v
    Jun 2011
    Oklahoma City, Oklahoma
    30
    5
    I just recently bought a an 04 cts v with almost 60,000 miles on it. This is my first cadillac, and I'm not very familiar with its odds and ends. Whenever I push it hard and rev it up into the higher rpm range and shift, I get a strong knock as I shift into the gear. The problem doesn't happen when I don't rev it up, and it shifts smoothly. Any ideas on what it could be?
  2. #2
    rand49er's Avatar
    rand49er is online now All V1s should be maggied.
    Jan 2005
    South Lyon, MI
    67
    13,803
    Re: Knock when trying to shift into higher gear while rpm's are high
    Need more info. Is this "knock" coming from the motor itself? Do you feel or sense a vibration? From the motor? Do you get a vibration from the motor when you turn it off?
    Skidmarcx and Skidmarcx like this.
  3. #3
    Skidmarcx's Avatar
    Skidmarcx is offline Cadillac Owners Fanatic
    Automobile(s): NONE!
    May 2011
    Phoenix, AZ
    38
    356
    sound clip will help
  4. #4
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    45
    4,000
    Randy's talking about your motor mounts. Common on the V.
    You gun it and the torque tries to rotate the engine lifting it off the mount. Then you push in the clutch pedal/back off the throttle and the engine drops back down making a thud. If this is what's happening then you need new motor mounts.
    Tony
  5. #5
    GDPossehl is offline Cadillac Owners Enthusiast
    Automobile(s): '04 CTS-V
    Feb 2011
    Decatur, GA
    504
    It's probably ALSO the rear differential bushing. It's soft and that torque will compress the front diff bushing (same effect as axle wrap) and when you clutch in to shift to 2nd the disconnected torque will quickly decompress that bushing and slam the axle back down which is the knock or banging noise you hear when shifting.
    Creative steel makes 2 products to reduce this effect:
    A polyurethane bushing and a "diff block" which goes above that bushing to further reduce movement.
    I have the poly bushing and it reduced that bang and other clunkiness at low speeds by %50. Much better.
  6. Remove Advertisements
