Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: After 74 mph carputer says traction engaged and i get loss of power
    KING03 is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS-V
    Jun 2011
    63
    Unhappy After 74 mph carputer says traction engaged and i get loss of power
    2005 CTS-V After 74 mph carputer says traction engaged and i get loss of power. what can this be?
  2. #2
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Re: After 74 mph carputer says traction engaged and i get loss of power
    Too much power, ease up on the throttle.
    J/K
    What tire sizes you running? Have you tried turning off traction control?
  3. #3
    Claimslngr's Avatar
    Claimslngr is offline Cadillac Owners Fanatic
    Automobile(s): 06' cts-v infrared
    May 2006
    south dakota
    243
    Twitch is right, check your tire sizes it sounds like the tires are of different diameter. The other cause could be a bad tpms, (no then it should happen all the time) nope still with Twitch!
  4. #4
    Jun 2011
    63
    yeah the tires are used diffrent brands and sized 240/40/18, just bought it yesterday ,going to put new tires on it today. I tried driving it without TC on but just dont like the feel.
  5. #5
    Claimslngr's Avatar
    May 2006
    south dakota
    243
    Can't remember the amount of difference percentage wise you can have, but it's not a lot. You have to check outside diameter to mix brands or sizes, maybe someone can chip in the amount of difference you can have.
    Good Luck
  6. #6
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Quote Originally Posted by KING03 View Post
    240/40 is tiny, but that's just my opinion. Is that what your mounting all around, or what you have on there now?
    If it doesn't do it with TC off then it should be your tires.
  7. #7
    Skidmarcx's Avatar
    Skidmarcx is offline Cadillac Owners Fanatic
    Automobile(s): NONE!
    May 2011
    Phoenix, AZ
    39
    356
    I agree on the tires... going 74 the difference in tire diameter makes enough difference, so there is a discrepancy in the wheel speeds
  8. #8
    tweeter81's Avatar
    tweeter81 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Mar 2005
    Gillette, WY
    35
    1,620
    It's more likely probably the wheel speed sensor going bad. Does it feel like the brake is slightly being applied to one wheel when the "Stability System Engaged" message comes up?
  9. #9
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Aug 2007
    Where the Navy takes me...
    6,461
    Quote Originally Posted by Twitch View Post
    240/40 is tiny
    And doesn't exist.
    yeah the tires are used diffrent [sic] brands and sized 240/40/18
    245/40-18? There's no such thing as a 240/40. Stock size is 245/45-18, so if you're putting new tires on it, get the proper size.
    It should feel exactly the same, unless you're spinning the tires continuously until you hit 74mph.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  10. #10
    Jun 2011
    63
    Could be me feeling freaked out with it off, yeah its 245/40 on one and 245/45 on the other, going to get all new wheels tomorrow, so i'll go from there and keep you guys posted
  11. #11
    kevm14 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 Stealth Gray CTS-V, 08 Light Platinum SRX V8, 05 White Diamond STS4 V8
    May 2008
    35
    1,357
    And there's your problem. You should be fine with proper sized tires all around. I'll never understand why people are incapable of using a simple tool like this to figure outer tire diameter (not the OP, but whoever put those tires on his car):
    http://www.miata.net/garage/tirecalc.html
  12. #12
    Jun 2011
    63
    yeah bought the car like that and already new i needed new tires, but don't know much about cadillacs thats why its nice to have help from a forum.
  13. #13
    tweeter81's Avatar
    Mar 2005
    Gillette, WY
    35
    1,620
    Quote Originally Posted by kevm14 View Post
    I have run tires that are as much as 5% different (smaller overall diameter) than stock and had no problems with the Stability system. GM obviously allows a little leeway in the system for people to change tire sizes. When you go up-size in width, you can't always find the exact O.D. that matches stock (especially if you are trying to get a certain tire brand or type).
    On a side note, when I had my car tuned, the shop reduced the amount that the TC and Stability intervenes when it's on in my car, so that could be part of the reason why I had no issues with a 5% difference in O.D.
  14. #14
    Jun 2011
    63
    new tires solved the problem
  15. #15
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Thanks for the update. So many threads drop of without answers.
  • You may not post replies
