Removing the center air vent above the nav screen
Results 1 to 4 of 4
Like Tree1Likes
  • 2 Post By JimmyH
2004-2007 Cadillac CTS-V General Discussion Discussion, Removing the center air vent above the nav screen in Cadillac CTS-V Series Forum - 2004 - 2007; I read the FAQ about removing the vent and it says "Pull it out"......from where? Do you pull the vent ...
    MSOsr's Avatar
    MSOsr is offline Cadillac Owners Enthusiast
    Automobile(s): 2011 Thunder Gray CTS-V coupe and Raven Black 2007 SRX
    May 2007
    Jacksonville, FL
    589
    I read the FAQ about removing the vent and it says "Pull it out"......from where? Do you pull the vent knobs toward you until the vent pops loose or do you pry behind the edges of the vent to pull it loose? I don't want to risk damaging something adjacent if there is an easy way to get the vent pulled out.
    Mike (not very mechanical)
  2. #2
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    Re: Removing the center air vent above the nav screen
    It does indeed just pop out. The easiest way would be to go to any hardware store, walmart, etc to the paint deptartment, and buy a couple plastic putty knives. Slide them in behind the bezel and just start prying.
    As an aside, the hvac bezel below the radio requires you to remove the ashtray and there is a screw to be taken out. Then the hvac bezel pops off the same way.
    Skidmarcx and Skidmarcx like this.
  3. #3
    MSOsr's Avatar
    May 2007
    Jacksonville, FL
    589
    Thanks, Jimmy!
    Mike (will be dodging WalMartians this afternoon)
  4. #4
    Dec 2006
    42
    37,302
    Also, the first time you remove it is a little difficult. After that it gets easier. Mine was removed and replaced so many times, I could pull it off easily by hand.
