HELP - is my dealer screwing with me
Results 1 to 15 of 15
2004-2007 Cadillac CTS-V General Discussion Discussion, HELP - is my dealer screwing with me in Cadillac CTS-V Series Forum - 2004 - 2007; So a 6 weeks ago I had a coolant leak, had to get my water pump replaced, had to haggle ...
    Hockeyref is offline Cadillac Owners Member
    Automobile(s): 2006 Black CTSV
    Jan 2011
    Manitoba
    54
    64
    So a 6 weeks ago I had a coolant leak, had to get my water pump replaced, had to haggle the price down to make it reasonable (somewhat). I noticed that my coolant is leaking AGAIN, now the tank under the rad is leaking, so its only 50 bucks more to do the whole rad so I might as well. BUT they are trying to figure out why my system keeps developing a leak. Pressure tested the cylinders and nothing found, now they want to pressure test the cooling system once its back together. I'm afraid the next step is a head gasket. Any suggestions out there? My bills are adding up WAY too quickly. Just bought the car in March and other than the cooling system it has been wonderful.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,213
    Re: HELP - is my dealer screwing with me
    I am not sure what "tank under the radiator" you are talking about. I have had my radiator out of the car many times and there is no separate tank "under the radiator." In any event, there is no mystery as to why you have leaks - the GM radiators notoriously defective in this cars. Some folks have replaced theirs 3-4 times. (I went aftermarket, but it was not cheap.)
  3. #3
    Jan 2011
    Manitoba
    54
    64
    Thanks for the quick reply darkman. I'm not sure on the tank either, have only had the car a few months. But only a few bucks more to replace the radiator so I have already committed to doing that. My fear is that they will find another leak somewhere and want to replace my headgasket. Gasket is cheap, labour is not. Are these engines known for head gasket problems?
  4. #4
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,213
    Quote Originally Posted by Hockeyref View Post
    Nope.
  5. #5
    Houdini's Avatar
    Houdini is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 CTS-V, 2010 CTS-V 6MT (Sold), 2007 CTS-V (Sold)
    Nov 2007
    St. Louis Metro
    1,405
    I bet once they get a new radiator in there you won't have a leak.
  6. #6
    Jan 2011
    Manitoba
    54
    64
    That sounds encouraging, thanks. Dealer will do a pressure test on the cooling system once the new rad is in, sure hope that takes care of it.
  7. #7
    kevm14 is online now Cadillac Owners Connoisseur
    Automobile(s): 05 Stealth Gray CTS-V, 08 Light Platinum SRX V8, 05 White Diamond STS4 V8 1SG
    May 2008
    36
    1,385
    Are the end tanks not on the top and bottom of the radiator? Is that not the typical issue with these?
  8. #8
    Jan 2011
    Manitoba
    54
    64
    Not sure, my car's sitting in the shop right now - hope to have it back soon...
  9. #9
    cam3439 is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Nov 2010
    106
    It sounds like they are talking about the end tanks that cap both ends of the radiator (upper and lower ends). I don't know if this is where these radiators develop the leak though.
  10. #10
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,537
    I'm sure the "tank under the radiator" is actually the bottom tank of the radiator. As already mentioned, the radiator has top and bottom "end tanks". There is no "tank under the radiator", there is just the radiator itself.
    This comment confuses me. Did they offer to replace the "tank under the radiator", and then offer to replace the radiator itself for only $50 more?
    I don't think there's any reason to think a head gasket would be next on the list.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  11. #11
    Jan 2011
    Manitoba
    54
    64
    They told me the tank was leaking, another $58 to do the whole radiator while it was apart so I said ok. Should get the car back at the end of today, then will keep an eye on the coolant level - hopefully this will be the end of it as long as the coolant level stays up.
  12. #12
    RADEoN is offline Banned
    Automobile(s): Olds Aurora
    Mar 2009
    Greensburg PA
    199
    mine leaked from the tank too. Something tells me you A, didn't need a water pump, or B, the tech there broke the radiator somehow.
  13. #13
    BirdmanTamu's Avatar
    BirdmanTamu is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Oct 2007
    Houston, TX
    37
    188
    The factory radiators have plastic top and bottom end tanks that are connected to the radiator via metal tabs. They leak at that interface between metal tab and plastic; usually biased towards the return side.
  14. #14
    Jan 2011
    Manitoba
    54
    64
    Got the car back today with the new rad no leaks so far but will have to keep an eye on it for the next while. Now myTPM sensors won't work after disconnecting the battery. They tried to get the module to read the sensors but no luck even though the sensors are working and doing a reset. Waiting for a response from GM
  15. #15
    Jan 2011
    Manitoba
    54
    64
    So my TPM sensors started working the next day, coolant seems to have stopped leaking - all is good. Thanks everyone for you input, much appreciated.
  16. Remove Advertisements
