Real High Oil Temperatures on Maggied V
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
2004-2007 Cadillac CTS-V General Discussion Discussion, Real High Oil Temperatures on Maggied V in Cadillac CTS-V Series Forum - 2004 - 2007; Yesterday I was driving down the freeway way at normal speed (80F outside) when my oil temp warning goes off. ...
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    30
    979
    Yesterday I was driving down the freeway way at normal speed (80F outside) when my oil temp warning goes off. I have done the grounding fix and prior to the maggie it worked great. I pulled off into a gas station and I could smell a distinct burning. I pulled the dipstick to check the oil level and smoke came out! The temperatures are sporadic, moving between 270-330F but always reading very high. I have a feeling the oil is actually getting this hot. What should I check first? I could not find any posts with similar issues.
  2. #2
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,207
    Re: Real High Oil Temperatures on Maggied V
    What are your coolant temperature and oil pressure levels doing when the oil temperature gets high?
  3. #3
    mstrjon32 is offline Cadillac Owners Enthusiast
    Automobile(s): NONE
    Oct 2010
    Mainz, Germany
    788
    FWIW, when I pull the dipstick immediately after shutting the engine down, I always get smoke. The dipstick tube is right next to the manifolds, which are quite hot.
  4. #4
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,454
    The fact that the temperature is moving around indicates to me that it's not accurate (in other words, that you've got an electrical issue again). The oil temp sensor is in the oil pan sump measuring the temperature of what should be a pretty good pool of oil. Oil doesn't change temperature in either direction quickly - it heats up more slowly than the coolant, and then it retains heat longer than the coolant.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  5. #5
    Mar 2010
    San Jose, CA
    30
    979
    Quote Originally Posted by darkman View Post
    45psi@ 70mph and 195F for engine coolant temp nd up to 201F when i was slowing down. Today it was consistently 275F to 280F on the freeway. I am concerned more because of the burning smell.
  6. #6
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,207
    Quote Originally Posted by OneFast V View Post
    As AAIIIC reported, the signature of the faulty sender/ground condition is erratic oil temperature levels since the actual oil temperature simply cannot change in either direction very quickly. How erratic is has the oil temperature been? Your coolant temps don't seem to indicate a hot engine although the oil pressure seems on the low side of normal. I would change out the sender and redo the grounds before I went looking for other, more expensive causes. Finally, you could check the temperature of the oil filter/oil pan with an infrared thermometer (cheap at Radio Shack) after a high temperature drive.
  7. #7
    Mar 2010
    San Jose, CA
    30
    979
    when im cruising on the freeway, the oil temperature appears to be very consistent. When i start to slow down and got off the freeway the readings then start going all over the place. I have redone the grounding spot multiple times, cleaned it off with a wire brush and added a star washer, so I'm not sure what else i could do for that ground. what is normal operating oil pressure? when i come to a stop or slow down the pressure drops to 32-36psi.
  8. #8
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,207
    I believe oil pressure, once completely warmed up, is around 55psi when cruising. The fact that the oil temp goes "all over the place" under any circumstances leads back to guage system. If the grounds are good then it must be the sender.
  9. #9
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    Idle after warm up is between 32 and 36 psi with about 10 psi increase for every 1k rpm (roughly).
  10. #10
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    As a point of reference, I just drove 275 miles this afternoon at an average speed of 79 MPH (~2,200 RPM) in about 80 deg F air and watched my coolant temp (solid 195 deg F) and oil temp (steady 219-221 deg F) and oil pressure (129 psi). Forget that last one.
  11. #11
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,207
    Quote Originally Posted by rand49er View Post
    "80 deg F" - must have a bloody cold front up there. That is a night time low down south.
  12. #12
    Mar 2010
    San Jose, CA
    30
    979
    at idle i'm at 33 psi, at 2000 45 psi and 55psi at 3000 rpm which seems normal.
  13. #13
    Mar 2010
    San Jose, CA
    30
    979
    Does the CTS-V have an oil cooler bypass valve? it seems like something that could be stuck open if it indeed has one.
  14. #14
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,207
    No oil cooler and no bypass valve. A lot of folks on this forum have had the problem with the high oil temperature. I don't recall any instances where the problem turned out to have a cause other than the gauge system itself (sender, wiring, grounds).
  15. #15
    mberisha's Avatar
    mberisha is offline Cadillac Owners Connoisseur
    Automobile(s): '11 Black Escalade AWD & '06 Black CTS-V
    Aug 2009
    Aviano, Italy
    38
    1,898
    Quote Originally Posted by mstrjon32 View Post
    Yup...that is a fact...I'll post of vid later of the smoking dipstick after an AutoBahn run....pretty common for long sessions of 5k+ rpms.....
    However....that doesn't sound like the OP's case though....
  16. Remove Advertisements
