new trans installed but hard to shift and drivetrain whine presists
Results 1 to 7 of 7
2004-2007 Cadillac CTS-V General Discussion Discussion, new trans installed but hard to shift and drivetrain whine presists in Cadillac CTS-V Series Forum - 2004 - 2007; I have 07 V with 72k and took it in for drivetrain noise. I figured diff but dealer instead replaced ...
    garrettg is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2009
    246
    I have 07 V with 72k and took it in for drivetrain noise. I figured diff but dealer instead replaced trans with new unit and also replaced clutch slave and clutch switch as they found it hard to shift when taking it for test drive. I get the car happy it has a new trans and slave but its really hard to shift gears now. Shifting up to 5th or 6th and back down to 5th from 6th especially takes a lot of force and precision. I have a pisnuoff modified stock shifter and bushings. Also to boot the drivetrain noise is still present. They agreed to look at again on Monday after waiting 12 days for a new trans to arrive and be installed, but any ideas what either of the issues could be?
    I did some searches and plenty of people state their diff's whine which is why I took my car in to begin with but could a motor mount cause this sort of issue or maybe the clutch has finally given up. One of the motor mounts was changed about 40k ago and afaik its the original clutch. I am sure the clutch is due but are certain gears harder to find as the clutch starts to fail?
    The drivetrain noise is from 2k-3k rpm in 4th-6th gears and also when engine braking through that rpm range, can hear a higher pitch noise coming from either trans or further downstream in the drivetrain.
  2. #2
    Jan 2009
    246
    Re: new trans installed but hard to shift and drivetrain whine presists
    Update: Dealership is ordering new diff but says small amount of whine is normal. Also states new transmission is tight and will take some time before 5th 6th gears can be accessed easily in all situations and motor mounts were said to be ok by dealer.
    I suspect the clutch is dragging but will give it some time. I have planned to do a ls7 clutch at some point this year but if this thing doesn't loosen up in the next few weeks my hand will be forced to go ahead early with it.
  3. #3
    Jan 2009
    246
    Solved: Serial 0006450001210E installed (assume this is gen4) and its quiet. I could always get noise around 2-3k in 4th/5th gears but now all I can hear is the stump pulling ls2.
  4. #4
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    Wow ... three posts and all is well.
  5. #5
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    What's the part number? That'll tell you if it's a gen 4 diff.
    And it probably is since that's probably all that is available...namely a dealer getting one. When the dealer replaced mine under CPO, it was a gen 4.
  6. #6
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Lol, sweet! People answering themselves!
    Bleed your clutch.
  7. #7
    CadzillaTN's Avatar
    CadzillaTN is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Apr 2008
    2,061
    Doesn't matter, they all howl like a wolf at some point!
    Aaaaaooooooooooooooooooooooooooooooooo.o.o.o..o... o.......
  8. Remove Advertisements
