Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: K&N Intake popping off problem
    bbmurphy is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Dec 2006
    10
    OK, I need help on this one guys. I have searched to the end of the internet and cannot find anything on this issue. The problem I am having is the K&N cold air intake I have on my 05 V keeps poping off the throttle body. I have checked all nuts and bolts, everything seems to be fastened correctly, yet that intake tube keeps slipping out some way or another. Any help or advise would be great! thanks guys!
  2. #2
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    Re: K&N Intake popping off problem
    You can replace the connecting tubes and clamps.
    I used silicone tubing.
    http://boostcontroller.com/
  3. #3
    CancerJCC is offline Cadillac Owners Connoisseur
    Automobile(s): 04' Blown CTS-V 554rwhp 497rwtq
    Aug 2009
    Georgia
    1,786
    You shouldn't have any pressure causing the K&N to "pop" off. I can see if you were turbocharged or something. Did you tighten down the worm gear clamps sufficiently? I had no problems for a lot of miles with my K&N.
    Also you could look into t bolt clamps as well, not only do they hold much better but they look "cleaner" as well IMHO.
  4. #4
    Nov 2004
    8,788
    It is the motor "torquing over" that breaks the connection.
    You may need motor mounts also.
  5. #5
    Dec 2006
    10
    Yea, I don't believe it's a pressure issue, I think it is a torque issue. IMO I think the motor is shifting and causing the tube to pop off. So you think it's a motor mount issue then?
  6. #6
    mberisha's Avatar
    mberisha is offline Cadillac Owners Connoisseur
    Automobile(s): '11 Black Escalade AWD & '06 Black CTS-V
    Aug 2009
    Aviano, Italy
    38
    1,898
    Quote Originally Posted by heavymetals View Post
    yeah that...I have a K&N CAI as well...no "popping off" issues....
  7. #7
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Bunch of noob answers
    Try loosening the bolts that hold down the shroud. That way the whole kit will move with the motor.
    Tony
  8. #8
    mberisha's Avatar
    Aug 2009
    Aviano, Italy
    38
    1,898
    Quote Originally Posted by Twitch View Post
    Tony
    True...but that doesn't fix the cause of the original problem (i.e. possibly bad motor mounts)...which could maybe lead to other more costly repairs...
  9. #9
    Dec 2006
    10
    Is there a sure tell of bad motor mounts? Never though of loosening the intake, I tried to do the opposite, tightened everything...
  10. #10
    Skidmarcx's Avatar
    Skidmarcx is offline Cadillac Owners Fanatic
    Automobile(s): NONE!
    May 2011
    Phoenix, AZ
    39
    356
    A sure tell sign is if you hear the engine bang around when you load it... I agree just leave the intake mounts loose, so it has freedom to move. I had the same problem when my mounts were bad
  11. #11
    Dec 2006
    10
    The only noise I hear is when I get in it and then I go to shift and I hear this loud clunck. But I read somewhere this could be the engine torquing over and that it's normal.
    Thanks for all your help on this guys! You have saved me hours of endless research on this.
  12. #12
    Dec 2006
    10
    Correction... When I get on it... Auto correction put, in it.
    So basically when I put my foot in the gas.
  13. #13
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Just loosen the shroud so it moves with the tube. Keep the tube/MAF tight.
    Sounds like you need new mounts. Just to be sure, you hear a thud after you floor it as your pressing in the clutch pedal, right? This is what mine was doing as the engine dropped back onto the mount.
    Tony
  14. #14
    Dec 2006
    10
    Exactly Tony, that is exactly the noise I hear. So I need to replace the motor mounts then. Did you have to replace both or just one? Did you use stock or aftermarket mounts? Lastly did you do it yourself or have it done. Thanks Tony
  15. #15
    Skidmarcx's Avatar
    May 2011
    Phoenix, AZ
    39
    356
    I'd replace them all with aftermarket... Creative Steel makes awesome mounts
  • You may not post replies
