how important is the small cross-member under exhaust that bolts up under the body?
Results 1 to 9 of 9
2004-2007 Cadillac CTS-V General Discussion Discussion, how important is the small cross-member under exhaust that bolts up under the body? in Cadillac CTS-V Series Forum - 2004 - 2007; Once again I am under my car trying to align my exhaust tips and fiddle with all the pipes involved ...
    bneal1022's Avatar
    bneal1022 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS-V, K&N, Borla, short throw w/ Holden knob, hotchkis
    May 2009
    40
    906
    Once again I am under my car trying to align my exhaust tips and fiddle with all the pipes involved in an aftermarket exhaust, cutouts, headers, etc... In some cases the mid-pipes lightly touch the cross member and with adjustment they stay off it.. or with the help of some washers to lower it.
    What is the purpose of this 1"x10" cross beam? support in the even of a big downward bump? or actually contact the exhaust pipes and support them at all times? Do I really need it? i have kooks, cats, cutouts, borla in that order.. never mind aligning the tips - that is impossible to KEEP them centered in the rear valance. thanks Team V.
  2. #2
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,181
    Re: how important is the small cross-member under exhaust that bolts up under the bod
    I believe the original purpose is merely to prevent (or at least help prevent) the exhaust system from hitting the ground immediately if another part of the attachment system (rear hangers or front bolt works) failed.
    My OEM catback has always ridden slightly above it and does not therefore, use it for constant support.
  3. #3
    kevm14 is offline Cadillac Owners Connoisseur
    Automobile(s): 05 Stealth Gray CTS-V, 08 Light Platinum SRX V8
    May 2008
    35
    1,354
    My left Magnaflow tip is off-center, to the right, and I don't think there's anything I can do about it. The pipe fits poorly along the rear cradle, too. Oh well. I didn't install it but I've heard this is typical.
  4. #4
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    I don't think you have to have it... like said above, it is nice when removing the exhaust hat it holds it up there a little. i don't see anything structural though, and the exhaust is not suppose to ride on it.
    I doubt the exhaust will flex enough while driving to hit it that it would restrain it either.
  5. #5
    Skidmarcx's Avatar
    Skidmarcx is offline Cadillac Owners Fanatic
    Automobile(s): NONE!
    May 2011
    Phoenix, AZ
    38
    356
    My exhaust is rubbing on it... looks like it's there to prevent pipe damage on the stock setup
  6. #6
    jaskel's Avatar
    jaskel is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Maggied CTS-V
    Aug 2009
    Riverview Fl
    140
    Yeah... I removed mine long ago, or rather a bolt fell out an I just finished the removal, and have yet to have any problems. 1 less piece to remove when messing with exhaust/driveshaft
  7. #7
    Houdini's Avatar
    Houdini is online now Cadillac Owners Connoisseur
    Automobile(s): 2016 CTS-V, 2010 CTS-V 6MT (Sold), 2007 CTS-V (Sold)
    Nov 2007
    St. Louis Metro
    1,404
    Yeah most people have removed it and I haven't heard of any problems. It is certainly just there for safety, not constant support. My oem system always sat above it but with my magnaflow I could not use it more than a day because it would eventually start making noise by hitting the pipes. You'll be fine to take it out. It's not worth the hassle.
  8. #8
    bneal1022's Avatar
    May 2009
    40
    906
    gone... thanks team V
  9. #9
    repenttokyo is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Jan 2009
    1,171
    Quote Originally Posted by kevm14 View Post
    mine is too.
  10. Remove Advertisements
