What sensor controls the oil life meter
Results 1 to 7 of 7
2004-2007 Cadillac CTS-V General Discussion Discussion, What sensor controls the oil life meter in Cadillac CTS-V Series Forum - 2004 - 2007; Just pulled the car out of storage for the winter and did my normal routine of changing the oil putting ...
    Mallett Hammer is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Jul 2008
    Wisconsin
    96
    Just pulled the car out of storage for the winter and did my normal routine of changing the oil putting fresh gas in it and checking all the vitals. After changing the oil about a 100 miles later the change oil light came on. I thought it was strange being that I just changed the oil. So first thing I did was check the oil pressure gauge....cause I was driving when it triggered. Upon arriving at my destination I checked the dipstick and the level was normal and oil still looked cleaner than ever. I have tried resetting it and disconnecting the battery to see if it would reset, but neither of those things fixed the issue. Now I am thinking that whatever sensor controls the oil life meter might be faulty. What sensor controls that?
    Has anyone else had this issue?
    Thanks in advance.
    P.S. - After I get this last little kink worked out and fixed I am thinking that the car is going to go up for sale. Other than that little glitch the car runs just as I remembered...and man did I miss it all winter. I just took a new job and will begin consistently traveling and won't really have the time to drive and really appreciate this awesome car. Stay tuned for the for sale ad that will be posted late next week.
  2. #2
    POS VETT is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Mar 2010
    44
    274
    Re: What sensor controls the oil life meter
    Umm, there is no sensor for oil life meter. The PCM uses a set of algorithms to calculate the remaining oil life.
    There is a procedure to reset it which I can't remember now (but might be as easy as displaying the meter and hit reset). Disconnecting battery doesn't reset it. RTFM.
  3. #3
    rlj5's Avatar
    rlj5 is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ProCharged cts-V -Silver on Black
    Aug 2005
    Indy
    68
    673
    on the info screen "oil life" push the reset & hold in down till it resets to 100%........ Sometimes I've had to hold it for 10-15 seconds before it would reset
    F1-A ProCharged LS2/402 Forged w/AFR 225 heads & Fast 92mm intake |Meth | 1-7/8" kooks w/ Corsa |Stage V Trans by RPM w/ 9" Ford IRS |UUC Shifter |Msd shift lite |custom gauge pod w/dual interceptor scan gauges w/wide band |launch control |Line lock |Hre C-20 wheels |GY gsd3's 255/40/18 front & M/T 305/35/18 DR |Kw Coilovers
    Built & Tuned by EPP---------- 864 rwhp / 812 rwtq
    9" IRS built & installed by---- Madman Racing
    http://s478.photobucket.com/albums/r...view=slideshow
  4. #4
    Aurora40's Avatar
    Aurora40 is offline Cadillac Owners Enthusiast
    Automobile(s): '06 CTS-V
    Mar 2004
    The Old Dominion
    42
    728
    Quote Originally Posted by POS VETT View Post
    It is that easy.
  5. #5
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Also, motor oil should be changed before the car is put into storage.
  6. #6
    Jul 2008
    Wisconsin
    96
    Thats really interesting. I wonder what factors it looks at to try and determine the engine oil life? It would have to gather some sort of data from other sensors. Oil temp / oil pressure / miles you've driven / and probably a few others.
    Quote Originally Posted by Aurora40 View Post
    It is that easy.
    Indeed it was that easy I just had to sit and hold it for a really long time. Took probably 15 seconds. I never remembered it taking that long.
    [QUOTE=Also, motor oil should be changed before the car is put into storage.[/QUOTE]
    I agree 100% with you and I do change it before I put it in storage. When I change it before I put it away I substitute 1 quart of oil for Lucas fully synthetic oil stabilizer and drive it for say 100 miles before it goes away. That oil stabilizer does a great job lubricating the upper portions of the engine and puts a "protective film" on those parts. Upon pulling it from storgae I put another 100 miles on it then I change the oil back to just Mobil 1. I've always done this with all the cars I've owned and it has done wonders. ;-)
  7. #7
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    Quote Originally Posted by Mallett Hammer View Post
    Thats really interesting. I wonder what factors it looks at to try and determine the engine oil life? It would have to gather some sort of data from other sensors. Oil temp / oil pressure / miles you've driven / and probably a few others. ...
    Now, I've heard that instead of some sophisticated algorithm, GM found that simply counting sparkplug firings (maybe just one cylinder for simplicity) was sufficient to correlate with oil life. Apparently, those other parameters that affect it like temperature, average load (i.e. throttle opening), etc. must not vary significantly to worry about.
    Mind you, that's what I've heard.
  8. Remove Advertisements
