3rd Gear Issue - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
2004-2007 Cadillac CTS-V General Discussion Discussion, 3rd Gear Issue in Cadillac CTS-V Series Forum - 2004 - 2007; This sounded like the same issue I'm having with reverse which I'm pretty sure is the uuc bushings being a ...
  1. #16
    Castro's Avatar
    Castro is offline Cadillac Owners Fanatic
    Automobile(s): None
    Jan 2005
    DC
    34
    447
    Re: 3rd Gear Issue
    This sounded like the same issue I'm having with reverse which I'm pretty sure is the uuc bushings being a very tight fit (I've bled the clutch and my transmission is new) I find it goes half way usually and I have to really smack it in to engage all the way. But your highway speed aspect sounds like something else, if I were you I'd definitely bleed it first and see what happens. Good luck I hope it isn't a serious transmission issue.
  2. #17
    mcline86 is offline Cadillac Owners Fanatic
    Automobile(s): 07 Black CTS-V
    Jul 2010
    MA
    30
    136
    Re: 3rd Gear Issue
    Il give the clutch bleeding a try. Although i see this ending up with me having to once again bring it to the caddy dealer, short throw shifters dont effect any warranty do they? How do you go about bleeding the clutch? I have decent mechanic skills but most of my experience is on ATV's not cars.
  3. #18
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,164
    Re: 3rd Gear Issue
    Quote Originally Posted by mcline86 View Post
    Bleeding the clutch yourself does involve some risk in that a few forum members have broken the bleeding screw, which requires dropping the transmission to repair. On the otherhand some dealers are not particularly reasonable in terms of what they charge to bleed and flush the clutch system. (Mine is though). Finally, if you have a dealer do it I simply would not mention the aftermarket shifter since most dealers will not recognize it on their own.
  4. #19
    Jul 2010
    MA
    30
    136
    Re: 3rd Gear Issue
    How much does your dealer charge u for a clutch flush and bleed? I do have a CPO warranty. i dont know if i should just bring it to them and have them deal with it, seeing that I have the short throw and they may blame it on that if they did notice it.
  5. #20
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,164
    Re: 3rd Gear Issue
    I don't recall exactly, but it was something like $50-$60. I had it done at the same time I had some other things done.
  6. #21
    repenttokyo is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Jan 2009
    1,171
    Re: 3rd Gear Issue
    Quote Originally Posted by darkman View Post
    paying that price is well worth it to avoid the frustration.
  7. #22
    WesH8398's Avatar
    WesH8398 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2010
    Sarnia, Ontario, Canada
    34
    897
    Bleeding the clutch does suck, but it helps. And when you see the condition of the fluid you bleed out of there, you'll be happy you did it. I have 2 suggestions for ya regarding the bleed:
    1) get a Motive "power bleeder" or something similar
    2) use Amsoil brake fluid for the new stuff
  8. #23
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,164
    Re: 3rd Gear Issue
    Quote Originally Posted by repenttokyo View Post
    Sure is, but I suggest you establish the price up front - some have reported much higher charges such as $200 if I recall correctly.
  9. #24
    KaMaSuTrA's Avatar
    KaMaSuTrA is offline Cadillac Owners Fanatic
    Automobile(s): 05 Cadillac CTS-V
    Nov 2008
    Chicago, IL
    31
    346
    Re: 3rd Gear Issue
    *insert local Rape Crisis hotline number here*
  10. #25
    Jul 2010
    MA
    30
    136
    Re: 3rd Gear Issue
    I'l deff have the dealer do it if its 50-60 bucks. Even if it was 100 just saves me the PITA to do it.
    My clutch fluid was flushed about 14k miles ago and the fluid in the reservior is actually pretty clean still. Hopefully this does the trick though il hafta call the dealer for pricing this week.
  11. #26
    garrettg is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2009
    246
    Re: 3rd Gear Issue
    I had 3rd gear downshift issues as stated, didn't matter if I bled the clutch or rev-match. I might not have bleed right the screw just falls out everytime I try to bleed it and can't get anything to come out from the top until its just about wobbled out. I took the car in since its still under power-train warranty as I was also hearing whining in 4th, 5th, and 6th. I just got word they are putting a new trans in, so hopefully that takes care of any whining and also fixes 3rd gear issue. Also I had issues at times with reverse lockout not fully engaging so that should be fixed as well.
  12. #27
    Jan 2009
    1,171
    Re: 3rd Gear Issue
    reverse lockout is a solenoid issue.
  13. #28
    Jan 2009
    246
    Re: 3rd Gear Issue
    Got the new trans still shifted like crap, would get locked out of gears like 3rd, 4th, 5th, 6th and rev. I muscled it for about a month with the pisnuoff short shifter(probably compounded the real issue). Anyway I finally bought the creative steel motor and trans mounts. I haven't installed the motor mounts but I did install the trans mount as it states on their website and a few random threads on there that is can help fix shift issues. Also reading the threads about shimming stock trans mount to raise the trans so the aftermarket ds coupler would work right also seemed to get me thinking that the stock trans mount might be sagging. Well after installing the trans mount the car now shifts perfectly. I don't know if the linkage was at a bad angle with the short shifter/sagging trans mount or what but its so easy to find any gear now and shifts as I would expect with no resistance. For anybody having shifting issues with a short shifter I would take a looks at the cs trans mount. The difference between the cs and stock one is huge in size and strength. I will post a picture if anybody needs. I posted a picture on the ls1 and cc forums already.
  14. #29
    Jan 2009
    246
    Re: 3rd Gear Issue
    new trans fixed rev lockout issue so new solenoid with new trans I suspect
  15. #30
    mberisha's Avatar
    mberisha is offline Cadillac Owners Connoisseur
    Automobile(s): '11 Black Escalade AWD & '06 Black CTS-V
    Aug 2009
    Aviano, Italy
    38
    1,898
    Re: 3rd Gear Issue
    very scary when slamming into 5th at ~130ish....I only did it once....mstjon32 said he's done it on several occasions on the AutoBahn......?!?
    However....I almost pooped myself.....
  16. Remove Advertisements
