275/35 /18 tires up front with 305/35/18 rear ...........(can it be done)
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, 275/35 /18 tires up front with 305/35/18 rear ...........(can it be done) in Cadillac CTS-V Series Forum - 2004 - 2007; Ok.... Have Mickey Thompson drag radials on rear 305/35/18's Have 255/40/18's gsd3's up front & it has worked out fine. ...
    rlj5's Avatar
    rlj5 is offline Cadillac Owners Enthusiast
    Automobile(s): '05 ProCharged cts-V -Silver on Black
    Aug 2005
    Indy
    68
    673
    I'm gonna need some new front tires & I have 2 nearly new gsds's that were left over from the past ( 275/35/18's )
    So I thought if I could use these in front I wouldn't have to buy new tires for up front.
    In the past I've always kept tire diameter to less than 3% front to back & have never had a problem with stability control or ABS systems
    So, I'm asking if anyone has gone over 3% difference in diameter front to back ? ( would be like 3.15%)
    And has anyone run 275/35/18's up front "without rubbing" ?
    F1-A ProCharged LS2/402 Forged w/AFR 225 heads & Fast 92mm intake |Meth | 1-7/8" kooks w/ Corsa |Stage V Trans by RPM w/ 9" Ford IRS |UUC Shifter |Msd shift lite |custom gauge pod w/dual interceptor scan gauges w/wide band |launch control |Line lock |Hre C-20 wheels |GY gsd3's 255/40/18 front & M/T 305/35/18 DR |Kw Coilovers
    Built & Tuned by EPP---------- 864 rwhp / 812 rwtq
    9" IRS built & installed by---- Madman Racing
    http://s478.photobucket.com/albums/r...view=slideshow
  2. #2
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    Re: 275/35 /18 tires up front with 305/35/18 rear ...........(can it be done)
    where are people getting this 3% rule from?
  3. #3
    rlj5's Avatar
    Aug 2005
    Indy
    68
    673
    Quote Originally Posted by liqidvenom View Post
    It pops up on the tire size calculators ( if you go over 3% it comes up in red that your outa limits)
    So, I assume it must be a standard limit for automotive systems
  4. #4
    Feb 2009
    Long Beach Ca
    35
    2,741
    ohh ok i was just wondering, but people have run 265 ish up front no problem. 275 isnt that far off i think.
  5. #5
    tweeter81's Avatar
    tweeter81 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Mar 2005
    Gillette, WY
    35
    1,620
    I'll be running that front size on the track, it should work fine. (I might have to raise the front up a little, but that's no big deal)
    As for the diameter difference, I would strive to stick within the 3% margin, but my previous set of tires actually were as much as 5.2% different than stock (but not that different from front to back) and I had no problems whatsoever.
  6. Remove Advertisements
