Results 1 to 9 of 9
Thread: Please help - widest tire possible on Linea Corse 19x10???
    sciroccokid is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Feb 2011
    106
    What is the widest tire I can run in the rear on a Linea Corse 19 x 10? I don't want to rub at all.
    Thanks! I am going to order these tomorrow.
  2. #2
    WesH8398's Avatar
    WesH8398 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2010
    Sarnia, Ontario, Canada
    35
    897
    Without changing anything else, I've read that 275's are as wide as you wanna go in the back. Wider will likely hit trailing arms and/or rub fenders extreme circumstances. 245's for the front.
  3. #3
    Feb 2011
    106
    Re: Please help - widest tire possible on Linea Corse 19x10???
    Hey guys,
    I am actually getting the new Linea Corse LC855's (same dimensions as the corse's mentioned above, Front: 19x8.5 6x115 with a +40mm offset, Rear: 19x10 6x115 with a +47mm offset). I would love to get 285's on the back, but don't want to shoot myself in the foot.
    Any advice? Will 285's fit with a stock ride height without rub.
  4. #4
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,447
    At stock ride height I would say yes. Plan on running some decent negative camber.
  5. #5
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    These Bridgestone Potenza RE970AS tires might work: http://www.tirerack.com/tires/tests/...y.jsp?ttid=147
    Since I don't need A/S, I'm looking at the Michelin Pilot Super Sport in 245/40ZR19 (front) and 275/35ZR19 (rear), 26.7" dia and 26.6" dia, respectively.
  6. #6
    tony tone is offline Cadillac Owners Fanatic
    Jan 2009
    miami
    36
    337
    Quote Originally Posted by sciroccokid View Post
    Hey guys,
    i run 285s on 10.5 rear tucking, but my forged wheel has a very aggressive offset. from what i've seen thread after thread these lineas aren't exactly offset friendly... meaning many have posted 275s rubbing lowered or OEM height.
  7. #7
    JSR is offline Cadillac Owners Member
    Jun 2010
    Virginia Beach
    35
    12
    I currently run 275's on my Corsa's at stock ride height with no rub. I plan to go to a 285 and lower it 1" (GC). Taking a look in there I may have to roll the inside of the fender but it should clear. Any lower than 285 and I'd say its a gamble.
  8. #8
    WesH8398's Avatar
    Apr 2010
    35
    897
    Quote Originally Posted by JSR View Post
    Do you already have offset trailing arms installed? If not, I'm surprised. Take some aggressive corners with your radio off and windows up; I bet if you're on OEM trailing arms, they're rubbing on the inner wheel lip.
    As for lowering, I think you'll definitely need to roll the fenders to put 285's back there. My 275's are a bit cut up from hitting my fender lip at the 2 o'clock (pass side) and 10 o'clock (driver side) positions. It was really bad with the drop from h&r springs, but even with them shimmed up to result in about a good inch total drop, they still hit the fender lips on big, sudden bumps/dips.
  9. #9
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,827
    ^^^ Good info.
  • You may not post replies
