Door switch
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V General Discussion Discussion, Door switch in Cadillac CTS-V Series Forum - 2004 - 2007; I have an intermittent problem with the drivers door switch not making contact. Sometimes when I get in the DIC ...
    ronr's Avatar
    ronr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    May 2004
    Fenton, Michigan
    871
    Door switch
    I have an intermittent problem with the drivers door switch not making contact. Sometimes when I get in the DIC doesn't display my personalization message ("Buckle-up & hang on") and shows a "Personalization Off" message instead. When this happens the drivers door window, lock, mirror... controls don't work either. I can usually fix the problem by simply opening and slamming the drivers door and then all is well with the world.
    I could probably live with (and have) this but the bigger problem is when I park and this happens then locking the car with the key FOB results in all the doors locking except the drivers door which I either have to lock by pushing down the button or using the key from the outside (or slamming the door really hard so that the contact is made.)
    Has anyone else had this problem? Is it more likely the switch (and if so where is that thing), or contacts that need to be cleaned or the actual door module going bad?
  2. #2
    Jbawden is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS Vsport, 2016 Chevy SS M6
    Mar 2009
    Napa, CA
    45
    493
    Re: Door switch
    I searched and found this thread. I'm having the exact same issue. Any resolution?
    Thanks
  3. #3
    Mar 2009
    Napa, CA
    45
    493
    Re: Door switch
    Turns out it's the "door module". I'm not entirely sure what that is, but I suspect I (or the OP) would have had better luck in the regular CTS section since the parts are presumably interchangeable. Good thing to remember the next time a problem comes up, might be answered in the non-V forum??
  4. #4
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,833
    Re: Door switch
    Quote Originally Posted by Jbawden View Post
    ... I suspect I (or the OP) would have had better luck in the regular CTS section ...
    Good point.
