What's your most annoying mod - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 50
2004-2007 Cadillac CTS-V General Discussion Discussion, What's your most annoying mod in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by perfect I'm pretty sure that when I open my cutouts I tend to annoy most people. Does ...
  1. #31
    mberisha's Avatar
    mberisha is offline Cadillac Owners Connoisseur
    Automobile(s): '11 Black Escalade AWD & '06 Black CTS-V
    Aug 2009
    Aviano, Italy
    38
    1,898
    re: What's your most annoying mod
    Quote Originally Posted by perfect View Post
    I'm pretty sure that when I open my cutouts I tend to annoy most people. Does that count?!
    My truly most annoying mod was probably my stereo. I love good, rich sounding bass but the alternator in our V's just doesn't seem capable of delivering the current that my amplifier needs to satisfy my listening levels. I have built several boxes and tried several different combination of equipment to no avail. Everything is out of the car for now.
    Funny you say that....my Memphis draws alot of current too....and when the bass is way up...the interior of the car dims like a haunted house....0 gauge positive lead off the battery.....
    Alt is putting out about 13.7v-13.9v.....but I guess it just doesn't have the amps.....
  2. #32
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,001
    Quote Originally Posted by darkman View Post
    My Specter Werkes bushings creak like a fibersglass sailboat.
    My front Hawk HP+ brake pads have been silent since I installed two-piece front rotors, but my rear Hawk HP+ brake pads (also on two-piece rotors) squeal like crazy - I can turn heads at 50 yards when going through a residential subdivision.
    Both problems have resisted all of the usual remedies.
    Not a peep out of the Specter bushings. Only some diff whine. But that's almost gone now with the heavier weight fluid.
  3. #33
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,213
    Quote Originally Posted by Twitch View Post
    Did you use anything other than perhaps the recommended spray silicone when you installed them?
  4. #34
    Skidmarcx's Avatar
    Skidmarcx is offline Cadillac Owners Fanatic
    Automobile(s): NONE!
    May 2011
    Phoenix, AZ
    39
    356
    most annoying for me is the GC kit... clunking and rattling... doesn't help one of my FG2's is blown...
  5. #35
    wcryan is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS-V Maggied
    Aug 2009
    Escondido, CA
    28
    1,065
    X2 on the gc kit. Hate the noises
  6. #36
    JD03Cobra's Avatar
    JD03Cobra is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Thunder Gray 6MT
    Mar 2008
    Michigan
    45
    2,122
    ^^That would drive me nuts
    I went with the HPS hawk pads for less dusting...They squeak like an SOB & I get this rust color sticking to my OEM chrome wheels that isn't easy to get off. Going back to OEM pads and the Hawks are going in the garbage.
  7. #37
    ahahnu's Avatar
    ahahnu is offline Cadillac Owners Connoisseur
    Automobile(s): '05 LS6 V Stealth Grey; '14 Z71 SLT Sierra 1500 Stealth Grey
    Dec 2004
    Tailgating at Giants Stadium
    37
    2,821
    Twitch, I'm with you. My Hotchkis front bar sucks. I've replaced the original brackets that came with them since they bent. The second set the weld cracked. Now in colder weather something up there rattles real bad at lower speeds and small bumps. It annoys the she-ite out of me. This is the first spring in 4 years I haven't replaced the bushings, that simply band-aids the problem so to hell with it.
    My most annoying non mod problem is the rattle / creak out of the center stack from under the ashtray. Been going on for a few years and when I replaced the mounts (trans / motor UUC) early last year and stiffened up the whole shebang its gotten worse. But hey for 125,000 miles I can't really complain.
  8. #38
    EdmundGTP is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 CTS-V
    Aug 2009
    Tempe AZ
    35
    612
    Quote Originally Posted by mberisha View Post
    Concur on that one......CREATIVE STEEL has GREAT customer service.....
    There's one more for ya Max!
    ABSOLUTELY!!
    When I went to get my first CS diff bushing installed at the dealership, the tech said it wouldn't fit right since somehow my bushing bore was slightly larger than normal. My dealer tech contacted CS to let them know of the problem, and Max had his guys turn me out a CUSTOM diff bushing to fit my car. I can't think of many vendors who will go out of their way to custom machine a single off-the-shelf part for a one-in-a-million customer issue.
  9. #39
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Headers leaked so bad at first they caused a venturi effect and sucked in air which threw a lean code on the O2 sensors. Finally milled the flanges and installed ARP studs. Cost a bundle in tuning and rework to find out the problem. Fidanza clutch which I truly loved had a friction disc made of 200 grit sand paper. Lasted about 3 months. Car still sounds like a sewing machine because the FAST 102 is a big hollow bongo. Tuning a 112LSA cam is more expensive than installing it. Everything else went pretty smooth....so far.
  10. #40
    atdeneve is offline Cadillac Owners Connoisseur
    Jan 2006
    2,114
    Quote Originally Posted by JD03Cobra View Post
    If you plan on chucking them out, please send them my way. I need a holdover set for a V, so even if those are garbage, I'd readily toss them on temporarily rather than get a new set of pads only to throw them out soon thereafter.
  11. #41
    Castro's Avatar
    Castro is offline Cadillac Owners Fanatic
    Automobile(s): None
    Jan 2005
    DC
    34
    447
    Re: What's your most annoying mod
    Spectre Werks cradle bushings by far. The only problem is they work great. They really locked down the rear in addition to a Creative Steel diff bushing. It's a noticeably tighter feel now and there is no banging from occasional wheel hop in the wet. They are by far the most annoying because they transmit MASSIVE diff whine. That being said I had it before but NOTHING like this. If you have any whine whatsoever expect it to be majorly magnified by putting these babies on, that was my experience anyway.
    Edit: on the creaking issue mine aren't bad at all, occasional noise when reversing from a stop but only in cold weather I think. I used a lot of white silicone spray when installing, really coated them, and it's been about a year I'd guess.
  12. #42
    ahahnu's Avatar
    Dec 2004
    37
    2,821
    You think you have diff whine, try the OG Kars III kit. Hard mounted to the diff and bolted to the car...
  13. #43
    Twitch's Avatar
    Mar 2006
    NYC
    46
    4,001
    Nope. Thought only the GM TSB inserts creaked.
    Quote Originally Posted by Castro View Post
    Stock I had no whine. Add specter bushings and I got some whine. Add CS diff bushing, louder higher pitched whine. Put in Amsiol 75W-140, lowered the pitch but didn't quiet it down enough. You gotta draw the line somewhere and no way I was gonna take out my specter bushings. So the CS diff bushing had to go. Now with stock diff bushing, Specter and heavier fluid I can barely hear any whine.
    Hope this helps someone
  14. #44
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,833
    No problems with the Specter Werkes bushings, the HOTS bars, or the HPS Hawk pads, but the GC kit does produce clunking in the rear.
    The maggie was a problem today. My sister just about went white as a sheet when I redlined it in second gear and finally got out of the throttle at 85 MPH in a 55 zone ... in Mexico. She recovered quickly, though ... back in the U.S.
  15. #45
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,213
    Quote Originally Posted by rand49er View Post
    Yeah, I have found that after a couple full-lock powerslides the passengers stop commenting on any miscellaneous noises the V makes. Don't you mean Canada?
  16. Remove Advertisements
