CV Joint Gave Up The Ghost
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V General Discussion Discussion, CV Joint Gave Up The Ghost in Cadillac CTS-V Series Forum - 2004 - 2007; The inner driver side CV joint destroyed itself this week and left me stranded. I have been searching and have ...
    wgbanks's Avatar
    wgbanks is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Jul 2008
    Belleville, IL
    56
    58
    The inner driver side CV joint destroyed itself this week and left me stranded. I have been searching and have had no luck find a replacement. Does anyone know if the passenger inner is the same as the drivers side inner? I appreciate any info.
  2. #2
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    Re: CV Joint Gave Up The Ghost
    I believe they are the same, there is no reason they would be directional. (you could always pull the drivers side too,and check it out.)
    Out of curiosity what axle shafts are you running?
  3. #3
    wgbanks's Avatar
    Jul 2008
    Belleville, IL
    56
    58
    I have the Hendrix axle in the driver side. The driver side is the joint the came apart and there is no way to compare my broken one to the passenger side one. I have had no luck finding a driver side axle assemble but have found quite a few passenger side units. If the inner joint is the same from side to side I was going to use one of the units I have found.
  4. #4
    Jun 2010
    Arizona
    407
    Can you post up some pictures of the broken joint?
    How long have you been running the axle?
    From when i put in my DSS axles, they looked the same, i did not take any measurements, but if you order a passenger side axle, you can always compare the inner cv's and make sure they look the same before installing them.
    Where were you looking and finding the passenger side axles?
